spin a bearing on crankshaft
   / spin a bearing on crankshaft #1
dchilton
Bedford, Indiana
190xt, 7030 allis chambers
If you spin a bearing on your crank and the crank is still good could you just replace the bearing? As long as the clearance check good. It is on a 90 horse diesel tractor. Thank you
   / spin a bearing on crankshaft #2
Yes, it's possible to roll in a new bearing. However, I would find why the oil pressure was low on that cylinder first. I would pull the oil pump and have a look, see if any thing is not right.
   / spin a bearing on crankshaft #3
I recently completed a rebuild of an old Goldwing with exactly that problem. Sadly, the spun bearing
eroded some of the steel off the crank journal and increased the clearance. So I had to replace the
crank. If it had been in spec, I would have reused the crank with the new bearing inserts that I bought.
   / spin a bearing on crankshaft #5
Its very rare that I would take a chance on a simple replacement of the bearing without the very least a polish of all the surfaces in the shop. In most cases I would have the crank cut and resurfaced and buy the appropriate bearings for the new measurement. That's why they make so many different size bearing for almost all engines, a cut and polish cost almost nothing compared to most cranks.
   / spin a bearing on crankshaft #6
My MF135 partially spun a main end bearing. The engine was shut down before seizing.
The crank was pulled cleaned and polished and refitted.
I replaced the full set of bearing shells, new piston rings and a full set of gaskets and seals and put the engine back togather as I had very little money at that time.
It had done about 5000 hrs before the tractor was sold.
Good luck with yours.
   / spin a bearing on crankshaft #7
I'd be concerned about the condition of the block journal.
One engine I rebuilt with a spun main had to be sent to the machine shop for an align bore. It was that chewed up!
   / spin a bearing on crankshaft #8
Try it with Plastigage first, and think pessimistically when doing so.
Jim
   / spin a bearing on crankshaft #9
I had an old Toyota pickup that was used mainly for playing in the mud. It started making a light knocking noise so I pulled the oil pan (since it was lifted with large mud tires I could do it without remove the engine). The bearing partially spun but didn't damage the crank. I replaced it. It measured within range using plastic gauge and since I really didn't care too much about the engine I tried it. It ran for maybe 6 more months until I pushed the engine pretty hard while playing in the mud (those 2.4L 4 bangers didn't like to spin 38" super swampers) and it spun again. By the time I got it out of the mud the crank was shot. The engine didn't have great oil pressure to begin with so I wasn't surprised. I could have tried some motor oil honey to help keep raise the pressure but at the end of the day the bearing spun for a reason. Unless you resolve the reason it'll most likely spin again. In my case I would of had to replace all the bearings and probably more. So if you do it do I would do all of them and maybe replace the oil pump if it's in the oil pan and easy to get at.
   / spin a bearing on crankshaft #10
As previously stated, the concern is the condition of the mating surface between the back of the bearing shell and the block/main bearing cap.
It could cost less now to perform an proper rebuild vs rolling in a bearing then having the new bearing spin and tear the block and cap up.
2014 Infiniti QX60 AWD SUV (A55758)
2014 Infiniti QX60...
UNUSED Mini Excavator Hydraulic Thumb (A47477)
UNUSED Mini...
2012 International ProStar T/A Day Cab Truck Tractor (A55788)
2012 International...
15" Concrete Pipe (A53316)
15" Concrete Pipe...
16' Cattle Guard (A53316)
16' Cattle Guard...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
