spendy fan clutch
   / spendy fan clutch #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
just replaced the fan clutch on my 99 f450 with 7.3 psd.. ford part was like 400$!! napa was cheaper but even the counter person reccomended i use the ford one... yikes..
soundguy
   / spendy fan clutch #2
soundguy
Did you check with Navistar?
Jim
   / spendy fan clutch
naw I didn't..
   / spendy fan clutch #5
It really is unbelievable. There are some on our hinos that are over a thousand. But with you towing in the fla heat, don't mess around. I know you don't like problems on the road.
   / spendy fan clutch #6
soundguy
Another reason I ditched diesels...everything is more expensive from parts to fuel. With all the tractor towing you do, you may not have any other choice.
   / spendy fan clutch
i went with the ford one.. I figured it already had a 'used' one on there.. might as well put a new one on.
as a point of interest.. the part#/ date code on the one I took off was a 98 part.. so was obviously the oem fan clutch.
yep.. I'm hauling with that truck.. can't afford to be stranded out of state with a load because I save 200$ on a non oem part that cools the engine..
soundguy
   / spendy fan clutch #8
Jim
Checking with the enigne OEM is an excellant idea for engine parts, this often saves 20% or more (in some cases 50%+) on common parts like fuel lines, seals etc that are not vehicle specific. In many cases I would include thermostats and water pumps in that recomendation, but Ford is known for high quality thermostats as is Navistar, so either would be acceptable.
As for the fan clutch itself, that and the fan are engineered by the vehicle manufacturer and not the engine OEM so I would prefer vehicle OEM parts to ensure they are right.
I use RockAuto for most of my OEM parts needs (Motorcraft/ACDelco). In fact they offer the YB559 (Motorcraft #F81Z8A616DA) fan clutch for just a touch over $200.
   / spendy fan clutch #9
A silly little electro-engagement PTO clutch on a Craftsman lawn tractor is $200 + list. It's a head scratcher. Good thing the economy is rolling white hot and we're all experiencing the great recovery. :laughing::laughing: Sorry.
   / spendy fan clutch #10
Yep, crazy. We had to replace a water pump on a V8 GM this week. $389 for the water pump. The year earlier model was under $40.:confused2:
Chris
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2014 CATERPILLAR 289D SKID STEER (A51246)
2014 CATERPILLAR...
Pallet of Misc Fabrication Steel (A52384)
Pallet of Misc...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
20704 (A51694)
20704 (A51694)
