Speedi-Sleeve for TB tine shaft?
   / Speedi-Sleeve for TB tine shaft? #1
wesmann
Bronze Member
Western Massachusetts
YM 276D
Removed the leaking seal from my TB tine shaft. There's a pretty good groove in the shaft. Some one posted earlier about solving this problem with a Speedi-Sleeve. Does anyone know where I can buy them? The seal ID is 1 1/4". Can I order the new sleeve using that measurement? Any information and advice greatly appreciated.
   / Speedi-Sleeve for TB tine shaft? #2
if you have one of the older horse troybilt tillers than i would assume the the reason for the bad seal and groove in the shaft is because the bearings are worn and allowing the shaft to wobble hitting the medal part of that seal. will probably have to replace the shaft,seals and bearings.
   / Speedi-Sleeve for TB tine shaft? #3
Try an auto parts store. Don't mangle the seal when you remove it. Save it and take it in with you. The part numbers on the original seal may help in getting the proper sized speedi-sleeve. The parts catalogs used to have a directory in the back that would allow you to cross reference part numbers and physical dimensions. That's before they went electronic.
Thanks for responses. There's no play in the shaft. The seal has leaked since I installed it badly many years ago. I'm going to shim a new seal out so it rides on a new part of the shaft and hope.
2014 Jeep Cherokee Latitude SUV (A50324)
2014 Jeep Cherokee...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
20305 (A51694)
20305 (A51694)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
