Speed up reverse???
   / Speed up reverse??? #1
akpilot
Wasilla, Alaska
NH TC40DA
I have a TC40DA is there anyway of speeding up reverse?? It seems really slow. I....know it's a safety issue, but it's a pain in the rear :mad:
   / Speed up reverse??? #2
I believe you accidentally posted this in the wrong forum. Maybe you didn't notice the "JD" in the title "JD Owning/Operating".
There may be an adjustment in the linkage from the pedal to the transmission that will allow you get a higher speed when the pedal is at its limit. Depending on the setup, if you adjust for a higher maximum reverse speed, you may get a lower maximum forward speed.
Consider posting this under "NH Owning/Operating" so someone familiar with your tractor can give you a more definite answer.
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
BUNDLE OF 8" I BEAMS UP TO 49" (A54756)
BUNDLE OF 8" I...
