Speeco Splitmaster Wood Splitter?
   / Speeco Splitmaster Wood Splitter? #1
dcgrazier
Millheim, PA
Kioti CK20HST, JD GT235, Scag
I would like to purchase a 3 point hitch wood splitter for my Kioti CK20HST tractor. I would like to know if anyone has experience with or knowledge of the Speeco Splitmaster wood splitter sold through Tractor Supply. It appears to have many features that appeal to me. I would like to know how it operates with the GPM of your tractor and how much does it weight? Are you satisfied with the implement and would you purchase the unit again or buy another wood splitter?
Thanks for your response and any information you share.
   / Speeco Splitmaster Wood Splitter? #2
Hi Dave - welcome to TBN from north central MD
Many folks are perfectly happy with this splitter. Good is that you have one fewer engine to maintain and a lower initial cost. Bad is that they're a bit slower and weaker than classic stand-alone splitter. They also tie up your tractor when using. Not so bad for manageable sizes, but a pain for larger chunks that you could otherwise load onto the splitter with loader. 3-point lets you get the splitter low to the ground - maybe allowing you to roll the big pieces onto the splitter.
Let us know how you make out.
Mike
   / Speeco Splitmaster Wood Splitter? #3
Works excellent behind my KM454, but I'm thinkin' the flow rate of your Kioti pump might be less than mine (20 l/min), I run the splitter just fine at ~1100 RPM
Don't remember the exact weight, but think it's in the neighborhood of 400#. And yes, I'd recommend it to any consumer. Pretty sure thought, that commercial users would want something with a faster cycle rate. Never considered buying another one though, this one so far has been virtually bulletproof.
Mike apparently doesn't realize that this is a vertical/horizontal splitter with its own integral stand. For the big stuff that I can't manhandle to the tray, I rotate the splitter to the vertical position. Bust'em up into manageable pieces, while they're still on the ground. When all the big chunks are split to a size I can lift, then I rotate the splitter back to horizontal operation.
One shortcoming - since fixed at a local welding shop. The stand is a bit wobbly on irregular and soft surfaces. Horizontal leg braces about a foot above ground level stabilized it nicely.
//greg//
   / Speeco Splitmaster Wood Splitter? #4
//greg//
Yup - I had in mind that it was another type that let you put it flat on the ground...
Mike
   / Speeco Splitmaster Wood Splitter? #5
This may be a little late but I just bought and used a Speeco 3 pt. splitter. My tractor flows about 10 gpm @ 2500 psi. It is a little slower than a stand alone but not enough to matter to me,beats a splitting maul. I really like the horizontal/vertical option. I need to modify the legs so they'll fold up,they hang a little low for going over uneven ground.
   / Speeco Splitmaster Wood Splitter? #6
Bought one last winter to use with my Kioti DK 45, the splitter works great. We used it several weeks ago to split two dump truck loads of firewood and it split everything except two very large, knotty pieces. I use it in the vertical position all the time. No hoses come with it so expect to pay about another $100 for high pressure hoses and fittings.
PALLET OF DIESEL FUEL CANS (A45333)
PALLET OF DIESEL...
15 YARD HOOK LIFT ROLL OFF CONTAINER (A45046)
15 YARD HOOK LIFT...
AGT MY50R Mini Excavator (A44501)
AGT MY50R Mini...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A45046)
2019 ALLMAND BROS...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
