Specs on the New Gator and Bobcat UTV
   / Specs on the New Gator and Bobcat UTV #1
Seizmik
I am passing along specs and information on the new John Deere Gator and Bobcat UTV痴. We just got these specs.
Here's the specs on the John Deere Gator:
-The engine is an in-line 3 cylinder, 815cc, water cooled, automobile engine (Cherry Automotive from China is their engine supplier)
-Dual Overhead Cam, EFI, 4 valves per cylinder
-50hp, 44mph
-Painted interior engine walls for longer life and corrosion resistance
-New hydraulic braking system, with twin piston front callipers
-New cargo box is largest in industry, on all models
-Reverse, brake, and taillights are standard on 855i, options on the other 2 models
-New double wishbone suspension
-New seating options all completely different than what they sell today
-New tire options, including radial tires on alloy wheels
-1400 lb payload, 1500 lb towing capacity, with suspension that can handle the loads.
-New XUVs are all about High Performance, ride, and utility
-Updated chassis of the 2007 version, heavily modified. 100% new front and rear suspension. Front end skin is redesigned to handle wheel travel.
-Same transmission type as previous model. H / L range. Same diff in the front, only engage full locking diff when traction is lost.
-New spring shifter eliminates gear grinding
-There is a whole portfolio of new attachments over 100 most are new to fit the new vehicle. UTV attachment business is significant to Deere.
-Base price: 825i $11,199 / 625i $9,899 / 855i diesel $11,299
Here痴 a link to the Gator info:
AgWired Blog Archives New John Deere Gator 825i XUV
Here are the specs on the bobcat UTV:
Bobcat 2200 4 x 4 Specifications:
200 (Gas)
2200 (Diesel)
Engine
Engine Cooling
Air
Liquid
Engine Fuel
Gasoline
Diesel
Horsepower
23 HP
20 HP
Performance
Operating Weight
1339 lbs
1475 lbs
Travel Speed
25 mph
25 mph
Travel Speed - Reverse
15 mph
15 mph
Capacities
Fuel Tank
6.5 gal
6.5 gal
Cargo Box Length
48 in
48 in
Cargo Box Width
50 in
50 in
Cargo Box Bed Load Capacity
800 lbs
800 lbs
Cargo Box Height
11 in
11 in
Cargo Box Bed Load Height
33 in
33 in
Total Vehicle Rated Capacity
1200 lbs
1200 lbs
Dimension
Length
124.6 in
124.6 in
Width
57.8 in
57.8 in
Height
78 in
78 in
Turning Radius
141 in
141 in
Wheelbase
82.7 in
82.7 in
Here's a link to the bobcat info: Bobcat 4x4 and 4x2 Utility Vehicles (UTVs) - Bobcat Company
Hope this was helpful, keep us in mind for all your Kubota RTV accessory needs.
-Seizmik
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
KUBOTA RTVX900 (A51243)
KUBOTA RTVX900...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
2018 Caterpillar...
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
