Spec's of the a 200CX loader on a JD 2210?
   / Spec's of the a 200CX loader on a JD 2210? #1
RRacing
saint leonard , MD
John Deere 4320
Spec\'s of the a 200CX loader on a JD 2210?
Does anyone know what the lift Height and weight is for the 200CX? The manual doesn't give any spec's /forums/images/graemlins/confused.gif
Thank you
Jim
   / Spec's of the a 200CX loader on a JD 2210? #2
Re: Spec\'s of the a 200CX loader on a JD 2210?
The manual that came with the loader should have those specs in it, not the tractors manual. At least that was the way mine is....
   / Spec's of the a 200CX loader on a JD 2210? #3
RRRACING,
Hopefully JohnDeere2210 will chime in; he has told me at his dealership that a 2210/210 against a 2210/200CS, has exactly the same lift height. The weight capacity I'll have to leave to him! /forums/images/graemlins/smirk.gif
Nope the loader manual has no spec's!!!!!I have looked 6 times and there not in there , The lift specs are also not in my 400CX manual either. But the brochure has them.
Jim
   / Spec's of the a 200CX loader on a JD 2210? #5
I've been digging around online for this too and have been unable to find it. Whats the deal?
   / Spec's of the a 200CX loader on a JD 2210? #6
Per the sales info:
Maximum lift height is 73.4 inches
Lift capacity to max height is 561 lbs, (at pivot pin)
Lift capacity to 59" is 706 lbs, (at pivot pin)
These specs stay consistent with the 2305 also...
/forums/images/graemlins/cool.gif
Thanks Dutch!
Jim
   / Spec's of the a 200CX loader on a JD 2210? #8
looks to me that the lift capacity of the 3ph is a little less. 20 lbs or so less 24 inches behind link arms. Not a biggie but ya have to wonder why it is less.
jd
   / Spec's of the a 200CX loader on a JD 2210? #9
</font><font color="blue" class="small">(
/forums/images/graemlins/cool.gif )</font>
This is also less isn't it? That would put it under 400lbs in the bucket. Seems like a step backwards to me.
   / Spec's of the a 200CX loader on a JD 2210? #10
yes,,, if you compare to the 210 loader,, the specs
are a bit shy. Tractor for tractor, the 200cx has the
same specs between the 2210 and 2305....
Fleco 30" 13.5-15.5T Excavator Bucket (A42203)
Fleco 30"...
SWEETWATER METAL PRODUCTS LINE TAMER TRAILER (A45333)
SWEETWATER METAL...
APEX Ag Equipment Hyperdisc H18/20 | High-Performance Tillage Disc for Precision Farming (A44789)
APEX Ag Equipment...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A42744)
2017 Ford F-150...
500 Gal Fuel Tank (A44502)
500 Gal Fuel Tank...
YANMAR  VIO17 MINI EXCAVATOR (A45333)
YANMAR VIO17 MINI...
