Specific oil?
   / Specific oil? #1
hoc342
taunton
JohnDeere111h
Don't know if I should purchase turf guard oil or a other brand for my John deere lt150
   / Specific oil? #2
I've not heard of "turf guard oil". Use what is recommended in your Op Manual. Remember - no manufacturer can require that you use their specific brand. They CAN recommend that whatever oil you should choose meets their minimum specifications.
   / Specific oil? #3
I use JD Turf Guard in my X739. Its not very expensive at the dealer and my engine only uses 2 quarts per year so why not use the recommended oil. If it was hard to find or extremely expensive I would just use an equivalent.
If you buy the John Deere maintenance kit it will come with Turf Guard oil. I will sometimes buy the kit if its on sale since it comes with air, fuel, oil filters and spark plugs for my machine.
   / Specific oil? #6
But who makes Turf Gard for JD? John Deere is not in the oil business, it comes from one of the major refineries. I use Valvoline in everything I own, always have and always will. Valvoline is the only major brand that refines it's own from crude (Ashland Oil Co.) and is only sold under the Valvoline brand. Gastrol, Quaker State, Penz, Mobil, Turf Guard etc all by their oil from a major refiner and add dyes and other additives and sell it under their name brand. "People who know, use Valvoline"
1979 Chevy step side-430,000 miles same engine, 1991 Isuzu pickup-326,000 miles same engine, 2002 Yukon-270,000 miles same engine, JD x300-805 hours. Nuff said.
   / Specific oil? #7
I only use AMSOIL Synthetic Oil in my X738. Have no use for JD oils, they are just repackaged oil company brands, e.g. Esso (Canada), Chevron and Philips 66.
Who Makes John Deere Lubricants
Source - MSDS
John Deere Hygard Transmission & Hydraulic Fluid Esso Petroleum Canada
JD Turf Gard 10W/40 John Deere Limited
John Deer Turf-gard 4-Cycle Motor Oil (All Grades) Phillips 66
John Deere Turf Gard Motor Oil 5W-30, 10W-30 Chevron Texaco Global Lubricants
John Deere Turf-Gard 4-Cycle Motor Oil 10W-30 Esso Petroleum Canada
John Deere Turf-Gard 4-Cycle Motor Oil 10W-40 Esso Petroleum Canada
John Deere Turf-Gard 4-Cycle Motor Oil 10W-40 Chevron Texaco Global Lubricants
John Deere Turf-Gard 4-Cycle Motor Oil 5W-30 Esso Petroleum Canada
John Deere Turf-Gard Supreme Motor Oil, SAE 10W-30 Conoco Lubricants, a division of ConocoPhillips
   / Specific oil? #8
Z71
You present only part of the information.. am somewhat familiar with the John Deere oil lab that is very intensive in the formulation of its oils.. contracted out to oil companies.. to JD specs. Not just a label change either.
Just tell the whole story..
But each of us can use whatever oil we like.. for whatever reason.
Cheaper is not necessarily a good reason. But if it works for you, fine.
   / Specific oil? #9
The idea that somehow the engine in my X738 (Kawasaki) needs a special oil designed by JD is ludicrous. OEM brand oils are minimum requirement aka good enough lubricants. There's obviously better made lubricants on today's market that meet and exceed OEM and do a much better job.
People IMO who swear by OEM lubricants are no more than fear mongering that everything else is just oil. This couldn't be farther from the truth. Regardless of what brand oil is stated or advertised by the OEM, these oils are nothing more than contracts that go to the lowest bidder. It doesn't mean by any means they are indeed the absolute best.
Recommending the best oil has never been the goal of any oem manufacturer, rather it’s a business decision. OEM’s recommendations are marketed to persuade buyers and even induce fear. It’s a business deal for the OEM to increase profits, not a quality deal for the consumer.
   / Specific oil? #10
The JD dealer that I bought my mower from told me that JD would not stand behind the warranty on my new X300 if I did not use JD oil. Well, I called John Deere offices and found out that it was not true as long as I used an acceptable grade and type of oil that met the engine manufacturer specs. I know this can be a Chevy vs Ford debate on oil brands but I am completely sold on Valvoline products, conventional and synthetic. There may be other brands as good but none better.
2013 INTERNATIONAL TA005 (A45046)
2013 INTERNATIONAL...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
2011 GMC Yukon SLT1 SUV (A42744)
2011 GMC Yukon...
2019 KENWORTH T800 (A45333)
2019 KENWORTH T800...
2017 Jeep Compass SUV (A42744)
2017 Jeep Compass...
2007 (INOPERABLE) INTERNATIONAL DF567 (A45333)
2007 (INOPERABLE)...
