Special tool for oil sump
   / Special tool for oil sump #1
gennien
Hi, I am new to the forum, I am from Malta, i own a Mitsubishi loader, and it has a special sump plug, which is not a normal hex or torx key. At first I thought it was a torx, but a torx has 6 points and this one has 8 points, and it has a star geometrical shape. the lenght from one point to the oppisite of the other side is 27mm.
Could someone point me to were i could buy a tool for this special key. All help is appreciated. Thanks
   / Special tool for oil sump #2
Looks to me to be a star socket.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Not sure if they would call them that there or not. But Ive started to see that there allot of these used recently.
I would be hoping that the poster, I forget his name with the car doing a burn out will weigh in on this I'm sure he would know..
   / Special tool for oil sump #3
Welcom gennien
Try a 3/8" or 1/2" ratchet with 8 points it wil take a square type of drive and should work fine ot a sutiable piece of key stock (square) and and open end wrench
tom
   / Special tool for oil sump #4
Like others have said try a piece of square stock and once it is out either find out what thread and pitch and get another plug or if you can not find something standard have a nut welded on the plug so you can now use a standard socket or wrench.
One other thought is a large flat blade screwdriver or like tool with maybe a pair of vise grips clamped on to get it out then find a replacement or weld on a nut.
Chris
   / Special tool for oil sump #5
It is a serrated wrench; most are 12 point (triple square), but there are also 8 point models (double square). All are metric; and a piece of square metric stock will work if it can grab enough surface to not strip the head. Lots of old German cars use the 12 pt serrated versions.
EDIT: In the US, KD Tools makes at least the 12 pt version, so they might make the 8 pt also.............
Hi, thanks for your replies. A serrated wrench is what it looks like to be, i am not sure if i could find such a large size ~25mm.
Thanks for your help
   / Special tool for oil sump #7
3/8 standard drive will fit that, and since it is a drain plug, it will not be so tight that you will need an 8 point.
Just use a ratchet handle like was previously posted. KennyV.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55218)
Bale Spear - Fits...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
UNUSED LANDHONOR PR-12-72W 72" HARLEY POWER RAKE (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
