Special No Override
   / Special No Override #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
   / Special No Override #2
Maybe this:
Engineering Essentials: Pressure-Control Valves | Hydraulics & Pneumatics
Cracking pressure and pressure override —The pressure at which a relief valve first opens to allow fluid to flow through is known as cracking pressure. When the valve is bypassing its full rated flow, it is in a state of full-flow pressure. The difference between full-flow and cracking pressure is sometimes known as pressure differential, also known as pressure override.
In some cases, this pressure override is not objectionable. However, it can be a disadvantage if it wastes power (because of the fluid lost through the valve before reaching the maximum setting). This can further permit maximum system pressure to exceed the ratings of other components. (To minimize override, use a pilot-operated relief valve.)
Bruce
Sounds good to me, Bruce. Thanks!
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
