Speaking of mower blades
   / Speaking of mower blades #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Just bought my first rider, an old Murray 12.5 horse B&S single. Ya I know but it was really really cheap, runs great and cuts grass..
How does the average home owner get the mower up so one can get under the deck to change, sharpen, check the blades?
   / Speaking of mower blades #2
Drive it up on a set of car ramps. Or lift it completely off the ground using straps and your FEL on your tractor.
   / Speaking of mower blades #3
I don't lift mine, I unhitch the deck & slide it out.
So I take it turing it on it's side is not a good thing to do, use to do my pusher on it's side, didn't seem to cause any problems.
Not sure if the deck comes off or not, it has a bunch of drive belts and pullys between the frame and deck and I am dreading even a belt breaking.
   / Speaking of mower blades #5
I never flipped my 18 hp on its side. I just use the ramps. My latest thoughts were to lift it to a nice workable level using 1500 lb straps and my FEL. I use my FEL on my 7275 to lift my Cub front end right off the ground. I put a set of jack stands under it for safety. Then I roll under it to dress up the blades on my 72" deck. Works for me.
   / Speaking of mower blades #6
TURNING IT ON IT'S SIDE IS NOT A GOOD IDEA! would be very surpised if the mower deck did not come off, eventually u wil have to chage belts and blades. did u get a book with it?
   / Speaking of mower blades #7
Get a 2 ton floor jack. ($25 at Wallyworld usually comes with 2 jackstands.) Jack it up, place the stands under it and go for it. Simple and safe. As for the belts, take a good close look and you will see that they are laid out in a logical fashion. If you have even a modicum of mechanical savvy you will have no problems on your mower. Yours is a very simple design.
Slam
   / Speaking of mower blades #8
<font color="purple">Before you remove any belts draw out a sketch of the lay out of the pulleys and the paths of the belts around them. </font>
   / Speaking of mower blades #9
</font><font color="blue" class="small">( <font color="purple">Before you remove any belts draw out a sketch of the lay out of the pulleys and the paths of the belts around them. </font> )</font>
Just take some photos. G
   / Speaking of mower blades #10
the plan is to unlink the deck slide it out and then you can pressure wash it or whatever - alternatively you can just leave it on and pressure wash through the hole where the grass comes out
flipping it on its side isnt a great idea but if you have to flip it carburetta side up exhaust side down
if a belt breakes youll be more worried about other things and not taking the deck oof - when mine broke it sure made a mess of the chassis deck and a tree about 20 foot away /forums/images/graemlins/blush.gif yikes
also if youre lifting the front up block the back wheels so it doesnt roll out off the stands - the parking brake might not be enough as it only breaks the translission not the wheels so it may still roll
wow so much writing /forums/images/graemlins/tongue.gif
mith
Dump body (A52377)
Dump body (A52377)
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2012 RAM 2500 (A53843)
