Tires Speaking of flat front tires...
   / Speaking of flat front tires... #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
Funny that this came up last week. My tractor's left front tire has lost pressure (down to ~6psi), gone flat sitting, gone flat running, and held pressure for weeks w/o problems. When low or flat, it always pumped right back up. Looked fine, but it's air storage capability is completely intermittant. Whatever. I figured it must be a function of loader work and cornering - I don't tend to go easy unless I REALLY have a lot of weight up front.
This weekend, I was clearing out the woods behind my shed - making a flat spot about 25x10 to park my tractor. I was also dumping and spreading a couple of loads a "driveway base gravel mix" (aka dug out septic stone/sand) over the area.
Other then backhoe work digging out a big half-rotted root ball, about 6-8 smallish trees/stumps, and a boulder or two, everything was done with my loader. I did a half-day and got the area dug out and graded, loaded about 95% of the gravel into the dug out area, and got it rough-graded.
I came out the next morning and my right tire was completely flat. I pumped it up, but it wouldn't hold air - air came gushing out of an area on the rim that was fairly dinged up around the edge - damaged there before I owned it.
I popped the bead on the tire (note below**), and cleaned up the loose debris at the area with a wire brush - I also smoothed the burrs of of the rim edge with a grinder, and smoothed the bearing edge in that area the best I could with the grinder. I sprayed a little engine-orange paint onto the rim as a rust preventative (then blasted the paint with my air compressor, as I was way too impatient to let it dry normally).
I gave the tire rim a squirt with WD-40, which tends to make rubber soft and tacky for a short while, so I thought it might help it stick to the rim (grip-installing trick from my dirtbike days). I pumped up the tire and it was fine to 20psi. It started bubbling WD-40 out of a teeny spot in the area I worked on when I pumped up to 30psi. I reduced pressure back to 20, then waited a few minutes for the WD-40 to do it's magic. When I noticed the liquid WD disappearing on the tire surface, I pumped the tire back up to 30PSI, and it held.
I put the rim back on, then finished my parking-spot job, which still involved a fair amount of loader work, as I had to move all of the dirt and debris that I dug out from where I piled it up, then dump it over a bank into the woods. Once the new pile I was making got big enough at the bottom of the the bank (~6-8' cliff, more or less), I was driving just a bit over the edge, then mashing down the pile stuff with my loader, then back drag up and over the edge. Eventally, it softened the bank edge, and mades for a decent looking trash pile that blends into the surrounding grades. I figured my backhoe could pull me out of just about anything, so I really took some chances. I throught for sure I was going to drive over the cliff and get stuck while teetering on my FEL, but I sort-of got used to looking straight down over my FEL, and I didn't get stuck even once.
When I was finally done, I drove my tractor up the street to a birthday party (why start up a whole 'nother vehicle?). The tire seems to be holding so far.
** Worthy of note: I have a Harbor-Freight portable tire-changing tool (Harbor Freight Tools - Quality Tools at the Lowest Prices)
that I bought to change ATV tires. I wasn't sure it would be effective on automotive-type tires, but I used it on my tractor tire yesterday, and it worked great - popping the bead off the rim was virtually effortless - way easire than soft-walled ATV tires.
JayC
   / Speaking of flat front tires... #2
Working in the brush and mud with my tractor my front wheels ocasionally get material forced between the rims and tire bead. I haven't had a damaged rim yet. I break mine down and clean it real good on the tire and rim and it's as good as new. It keeps more foriegn material out when I put maybe 30lbs in them.
   / Speaking of flat front tires... #3
I had my tractor 5 hours before I got flat on the front left. I foam filled them. I refused to have my weekend interrupted by a flat again.
   / Speaking of flat front tires... #4
I had the same problem of my front tire leaking air off. Then one winter it came loose from the rim. I re-seated it and pumped it back up. Just the other day, I pumped the tire up and moved about 8 ton of sand and 8 ton of stone. Then while the tractor was setting not being used, the tire blew out. I went and had it changed out ($80 for a new R-4 right front for B-7800) and I kept the old tire for a project I got lined up. Where the tire had been flat the rim cut all the cords on the inside and really chewed up the inside of the tire. Lesson learned to keep closer eye on tire pressure.
   / Speaking of flat front tires... #5
LeadPoison, I thought you were me for a moment...same here...same hours...never looked back...now 700 hours on the foam filled fronts...love them...
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
City of Lakeland (A51691)
City of Lakeland...
BUNDLE FENCE PIPE (A51244)
BUNDLE FENCE PIPE...
