gatractorman
- Joined
- Jan 27, 2002
- Messages
- 183
- Location
- Cleveland GA
- Tractor
- varies never keep one long enough to post here lol
As title states I have a spark problem, I have a service manual and going by it I checked voltage going to coil. I have none with the key on (manual says should have 30), and starting I have 30 (manual says should have 130). I dropped back to the trigger coil, the ohms on it are within specs 84-126 and I have 119. Starting trigger coil voltage, I have none. Manual says 3.??- 4.??. Took it apart, everything visually looks fine. I know that means little if anything. But is it possible for a trigger coil to ohm good and be actually bad?
