Flat Proofing Spare Tire Sealant
   / Spare Tire Sealant #1
KennyG
Elite Member
SW Michigan
John Deere 2320
I have a old (40 years) car that's kind of hobby/project. It didn't have a spare, so I found a rim (new) that fit it and mounted one of the tires I recently replaced. The tire looks new but I replaced it because it was 13 years old. I now have a leak around the bead on one side. I mounted it by hand so I may have been a little rough on the bead. Any ideas on sealing the leak? In the past I've used Slime on bicycle and motorcycle tires and all it seemed to do was make a mess. How will sealants work on a tire that isn't being driven? If I break the bead loose is there anything I can do to get a better seal. Everything was 100% clean when I mounted it. I'm kind of at a loss on this because it's something I haven't run into before.
Any suggestions appreciated.
   / Spare Tire Sealant #2
I once had a tubeless tire that had been repaired several times for punctures and the bead was pretty badly torn up from so many tire iron removals. It developed a bead leak so I broke the bead, laid down a bead of ultra gray on the exposed bead and aired it up enough to reseat the bead and let the air out to just a few psi over night then aired it up and is held.
I have since done that a time or two on my riding mower tires.
Some feedback. I tried Permatex and it worked. If I had to do it again, I might look for something clear. It pushed some sealant out when the bead resealed and I couldn't get it cleaned up well. However, it does hold air.
   / Spare Tire Sealant #4
What variety of Permatex did you use? Last time I had your problem I put a tube in the tire at a cost of around $25.00.
As for the sealant in an aerosol can. Around thirty years ago a guy who worked for a tire store recommended it and I tried several cans. They pumped the tire up and it went back down in short order. Hopefully the stuff works better these days.
   / Spare Tire Sealant #5
A poor man's beadlock often used by rock crawlers: roofing tar cement. Debead the tire, spread the cement around the rim area, rebead, reinflate to about 60 psi (temporarily) and wipe any that oozes out.
good luck.
I used the Permatex gray "moto-seal" because it's meant to come back apart. I didn't want the tire permanently sealed to the rim. I paid about $7 for a tube and used perhaps 1/4 of it. I broke the bead and smeared it on the tire bead. Only one bead leaked, so I didn't break the other one free.
   / Spare Tire Sealant #7
I just bought my second gallon of slime...
I bought it to "seal the bead" on two tires I have. The first gallon lasted me years and worked so good that, that's why I bought a second gallon!
BTW, The two tires are now holding air just fine!
SR
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
Pallet Forks for Tractor (A51573)
Pallet Forks for...
