Spare Tire for trailer
   / Spare Tire for trailer #1
jrepp44
Bronze Member
NW Louisiana
Kubota B2650HSTC
My current tires are P215/75R15 on a 15" rim. Is a ST205/75/15 on a 15" rim (that matches the current rim) an acceptable spare?
   / Spare Tire for trailer #2
Its a better tire than what you are running now if I remember my tire codes.
   / Spare Tire for trailer #3
Running a "P" tire on a trailer is asking for trouble. A "ST" tire is what you really want or many run "LT" tires.
As far as size difference goes a 215 is 27.7" tall and 6.3" wide while a 205 is 27.1" tall and 6.1" wide. The 215 takes 728/revs per mile while the 205 takes 744 revs/mile.
It will be fine as a spare. The real issue is why are you running a "P" tire on a trailer.
Chris
   / Spare Tire for trailer #5
Spare Tire - a tire that is often used temporairly to get a vehicle off the roadside to a more secure location until a more permanent solution can be obtained. **** yes use it as a spare. Anything that will roll and touch the ground is better than one that's flat on the bottom side.
   / Spare Tire for trailer #6
"P" stands for passenger.
If the "P" tire is with in his weight carrying capacity, I see no reason why he can't run it.
   / Spare Tire for trailer #7
"P" rated tires do not have the side wall strength to stand up for very long on trailer service. Especially on tandem and triple axle setups. Turning puts tremendous side loads that "ST" tires can withstand.
Chris
   / Spare Tire for trailer #8
Chris
Please, the OP did not specify what type of trailer he is using his tires/spare on, lets not cloud the issue by bringing in tandem, triple axles, etc. into the discussion until and unless needed.
   / Spare Tire for trailer #9
No, he didn't specify whether he had a single, tandem, or triple axle. However, bringing these into the discussion is appropriate for 2 reasons:
1) We're having to guess his trailer configuration to make the best recommendation. and
2) This forum has consistently provided answers to questions that were not asked, but should have been. (i.e. volunteered information that the OP may not be aware he needs to ask about.)
I appologize if this ruffles anyones feathers, but the above post ruffled mine.
   / Spare Tire for trailer #10
Your post didn't ruffle my feathers at all, but it's obvious the OP is a newbie, why throw in a lot of information to confuse things at the start?
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
Modine Shop Heater (A51573)
Modine Shop Heater...
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
Toro Mower (A50324)
Toro Mower (A50324)
