duckboy
I have 2 fencing projects to get done soon and I would appreciate tapping the genuis and expertise of TBN. The first task is a deer fence, 88 X 66 ft. Will be using 6 inch round treated posts, the green ones. 12 ft posts, 4 in, 8 up, with 4 inch wire mesh attached. Is 12 foot spacing OK? On the 66 ft runs, starting from the center point, there would be 3 feet from the last 12 ft space to the corner posts. Diagonal bracing would not work being that close, so I was going to do 3 horizontal braces using the same posts, ...with diagonal cable bracing in an 'X', with turnbuckles. On one 88 ft run, at the center point, the first spacing would be 10 feet, then to 12 feet, which will allow for the same 3 foot corner spacing, and bracing. The other 88 ft run will have a sliding 10 ft gate, 2, 5 ft panels on overhead barn door tracks. This will allow the same 3 ft bracing at the corners and gate posts. I'm not sure if I have had too much coffee this AM, or not enough....
does this sound reasonable for looks and stability?
The other fencing task will be a 3 rail horse pasture fence with the same treated posts, 8 footers, 3 in 5 up, with 2 X 6 rails. Occational horse use, but mostly to clean up the front of my property, and discourage the neighbors from climbing the apple trees. What is the best spacing for this....10, or 12 ft?
Thanks for your time and input.....
PR
PR
