Space in pivot joint
   / Space in pivot joint #1
AUSTENNN10
Alto nm
Ls 3033
G3033H
Upon greasing the center front axle zerk, underside center between the front wheels it appears the the 2 sections expanded away from each other like the grease filled a void or boot.
More info The grease point is where a left and right wheel frame part meets and looks like 2 short tubes stacked on top each other. On the side on the tube is the frame that goes out to the wheel. This combined tube is horizontal to the ground and runs front to back. When I greased it it appeared that the circular surface where they touch separated as it was filled with grease. Not seeing any grease I am assuming there is a boot inside.
Normal? My follow up will be having grease come out on the ground one day but that is for later.
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
New Holland HM236 Disk Mower (A50515)
New Holland HM236...
3014 (A50657)
3014 (A50657)
