handirifle
Veteran Member
Not a cover over the spa itself, but one over the pad the spa is on. The pad is 18' x 18'. The current plan is to build an either 4-12 or 6-12 pitch gable roof, covered with comp shingles. I have 6x6 post anchors already set in concrete, with appropriate footings. The rest of the pad is at least 4" concrete with 5/16" rebar on 16" centers.
This is going to be built as soon as I finish my current project, my workshop. It has a truss roof, but I had those made. Problem is, I am running out of funding, and am considering making my own trusses this time. My quotes are $80 each and I think I can make them for about half that. I will confirm this price before I make any final decision though.
I have the wood skills needed to do this, BUT what I am wondering is can I substitute plywood for the steel plates that hold the joints of the trusses together?
I think using 3/8" (or 1/2") ply or OSB (whichever is stronger) and nailed with pnuematic staples, 1 1/2" long (for 2x lumber), they would hold up as well as the steel plates, am I way off here?
Reading a bit on the net, I've seen some recommending using screws in the steel plates, but that seems like it would weaken the wood if you used too many screws. If you predrilled the holes it might not split, but that is tons more work than neeed be.
Hammering them on also has issues of the hammer force loosening the first side, while hammering the second side in. I do not have a press to press the steel plates on.
