Source for 8/3 extention cord wire
   / Source for 8/3 extention cord wire #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
I want to make an extension cord for my welder but haven't been able to source the 8/3 wire anywhere. The ready made cords you buy have the standard welding plugs on them and I'm set up for NEMA 10-50 plugs. I just need the wire.
Any suggestions? The Lowes big wire rack didn't have any and the electrical supply houses around here don't handle anything like that bigger than 10ga.
thanks,
Ian
   / Source for 8/3 extention cord wire #2
find a local electrical contractor supplier. 8-3 portable cable is not common, how much do you need?
Not a whole lot, maybe 15 feet. I may end up having to convert to the standard welding plug and just buy a pre-made 25 footer.
Ian
   / Source for 8/3 extention cord wire #4
contact a local electrician and pick his brain, maybe he has a piece left over from a job.
   / Source for 8/3 extention cord wire #5
You should be able to find it at an electrical supply store like posted above. What I think you are looking for is called S-O cord(at least in my neck of the woods it is). Round, flexable, rubber coated, just like a regular extension cord, just bigger
   / Source for 8/3 extention cord wire #6
Ian, I bet you would do fine with a 10/3 extension cord for your welder.
I had been using a 60' 12/3wg extension cord for several small projects with my Miller Thunderbolt before I found out it wasn't a 10/3 cord. It had been left behind by a contractor several years before.
Bottom line was that it worked fine and never got hot, even being 12ga.
I took my time cleaning the slag between passes and sticking closely to the cycle time and that probably helped the cord from getting too warm.
I wouldn't think there would be a problem at all with using a 15' 10/3 extension cord. I imagine that your machine has only a 12ga cord on it already.
I'm not saying for you to do it, but I'm just relating my experience.
   / Source for 8/3 extention cord wire #7
They are not cheap, but you might want to look at a 50amp marine or RV extension cord.
   / Source for 8/3 extention cord wire #8
why not buy a welding extension cord and make a pigtail ...(or change out the plug and/or receptacle...but the pigtail(s) would give you max versatility) ...25ft 8/3 cordsets start around $55
I've made such pigtails to get around the (stupid) Miller MVP problem
   / Source for 8/3 extention cord wire #9
Maybe not totally kosher, but I found lots of new 6 gauge THHN wire at my local metal scrap yard. It seems the electricians sell the ends off big rolls. I found pieces 25 feet or so. I cut three lengths, taped them together well and put plugs on the ends.
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A51247)
2019 JOHN DEERE...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A53426)
2010 PETERBILT 387...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
