Source for 30 Gal. barrels..
   / Source for 30 Gal. barrels.. #1
uhmgawa
New Hampshire
Kubota L48TLB
Anyone found an source for the above? Around here 55 Gal
drums/barrels seems to be common but not anything smaller.
Metal is preferred as this will be used to store diesel.
   / Source for 30 Gal. barrels.. #2
You might try the VeryFine plant in Littleton, MA.
   / Source for 30 Gal. barrels.. #3
Farm chemicals (roundup, etc.) are often shipped in 30 gal poly barrels. They work fine for diesel storage after cleaning.
   / Source for 30 Gal. barrels.. #4
Basco
Shiela Baney
1-800-776-3786
Tell her I sent you (Alan Bechard) and she will know you want the low price right off the bat!
   / Source for 30 Gal. barrels.. #5
</font><font color="blue" class="small">( Farm chemicals (roundup, etc.) are often shipped in 30 gal poly barrels. They work fine for diesel storage after cleaning. )</font>
What do you use to clean them with?
   / Source for 30 Gal. barrels.. #6
I just washed out with soapy water and rinsed several times, then let dry thoroughly.
   / Source for 30 Gal. barrels.. #7
</font><font color="blue" class="small">( I just washed out with soapy water and rinsed several times, then let dry thoroughly. )</font> Of course, you will want to use protective equipment when doing this as the pesticide can be easily absorbed through the skin. Use latex gloves (I use two pair) and then make sure you wash yourself well afterward. I also use protective eyewear to avoid splashes. Make sure you're doing it in an area where you don't care if everything dies as the residue is still quite toxic. John
   / Source for 30 Gal. barrels.. #8
Good points. Thanks. /forums/images/graemlins/wink.gif
   / Source for 30 Gal. barrels.. #9
I got some a few years ago and they were already cleaned by the end user. They told me that it was easier to get rid of them and they didn't have to worry about liability if they were previously cleaned. They actually had a label on them indicating that they had been decontaminated and the original warning labels were removed. They charged $10 each for them and it was well worth it for me. Only wish that I had gotten more of them at the time. Now they are no longer available. They return them to the point of origin. /forums/images/graemlins/frown.gif
   / Source for 30 Gal. barrels.. #10
That WAS a good price for those drums Junkman. I just bought two 55 gallon drums @ $20/each and was happy to get them for that. In a short while I bet they'll be $40 with these steel increases. John
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2006 Acura RL Sedan (A51694)
2006 Acura RL...
