soundman!!!!
   / soundman!!!! #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
good to see you posting, hope all is well with you /forums/images/graemlins/wink.gif
southern florida looks like hell /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
Did i miss junkman's reunion? did we have red hats and coffee cups /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
good to see all you guys posing, be glad when mark777 get back /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
good luck,
bluebonnet2
   / soundman!!!!
soundguy......soundguy...... /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
screwed that up......lol
still good to see your post
bluebonnet2
   / soundman!!!! #3
<font color="blue"> soundguy......soundguy...... </font>
I saw in a post a couple weeks ago where someone called him "Soundboy" /forums/images/graemlins/confused.gif
Soundman, Soundboy, Soundguy...
I think I'll stick with Chris! /forums/images/graemlins/grin.gif
While we're trying to change his name, I'm going to take this opportunity to nominate him as the next "TBN All-Star". His old tractor knowledge is phenomenal, and his advice in general has helped almost everyone here at one time or another.
Do I have a second on the motion? /forums/images/graemlins/smirk.gif
   / soundman!!!! #4
YEAH...I will cheerfully second your motion to nominate Soundman, er, Soundboy, oops, SOUNDGUY for all star membership.
And I'm sure he has been called a lot worse than the above names by the dummies who don't appreciate his wisdom and the contributions he makes to TBN.
THANKS CHRIS !!!! /forums/images/graemlins/smile.gif
   / soundman!!!! #5
</font><font color="blue" class="small">( I saw in a post a couple weeks ago where someone called him "Soundboy" )</font>
I got a kick out of that one.. I think I became my own side kick. ( the adventures of...soundguy and soundboy.. or something like that!
</font><font color="blue" class="small">( Soundman, Soundboy, Soundguy...
I think I'll stick with Chris! )</font>
I answer to many names.. just ask my wife.. especially when I come in with muddy boots ...
Yep.. south Fl got hammered. I brought my chickens and turkey into the barn to keep flying debri from hitting them thru their wire pens. I hear there are still many thousands without power down south.. and may be that way for days / weeks... yikes.. I feel for those people.
</font><font color="blue" class="small">( His old tractor knowledge is phenomenal, and his advice in general has helped almost everyone here at one time or another )</font>
You guys gonna make my head swell.. and I'll have to go buy new hats. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
Thanks for the kind words.
Soundguy
   / soundman!!!! #6
</font><font color="blue" class="small">( soundguy......soundguy......
)</font>
Like I told andym .. I answer to ( and for ) a lot of things from the wife!
Good to see all of you. There for a few days I was so busy around the farm, cleaning up from the weather I had little time to post.
I think this weekend I'm going to pull one of my 8n's into the garage and drop the hydro pump/ bottom cover, and the top cover and rebuild the lift cylinder, reseal the pump, and replace some valving. Should be like a new machine after that. She got a rebuilt carb, and new wire harness and some new ignition parts a few weeks ago.
I ronically I damaged her while cleaning up from the storm. I had a 30" rear scoop full of clay and dirt and was toting it around to fill in washouts along the fence. My last load was a bit too much for the 52 year old hydraulics, and I blew out the bottom gasket. She limped home, and I could simply drop the pump and reseal the bottom.. but I figure while in there i might as well 'do it right'. In any case... all the parts oil, gaskets and new piston / relief valve came to just a tad under a nundred bucks.. which isn't bad. Now I just need to add the elbow grease. Hope all the parts come in by friday, so I can start tearing it down. My plan is to have it done sunday night... hope it cooperates!
later guys!
soundguy
   / soundman!!!! #8
</font><font color="blue" class="small">( I think this weekend I'm going to pull one of my 8n's into the garage and drop the hydro pump/ bottom cover, and the top cover and rebuild the lift cylinder, reseal the pump, and replace some valving. )</font>
You make it sound so easy, like "drop the hydro pump/ bottom cover, and the top cover and rebuild the lift cylinder, reseal the pump, and replace some valving" then I'll have a glass of water and maybe eat a sandwitch.
Cliff
   / soundman!!!! #9
Sometimes I get lucky and it is that easy.. other times I will work for 2 hours getting a single bolt unstuck... go figure.
Soundguy
   / soundman!!!! #10
Yep if you have 6 bolts to remove, 5 will come out nicely /forums/images/graemlins/smile.gif
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2007 MCDANI TRI AXLE STEP DECK (A53843)
2007 MCDANI TRI...
CHERRY PICKER AND TRANSMISSION JACK (A53843)
CHERRY PICKER AND...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A53843)
RAKE ATTACHMENT...
