sotah beaver
   / sotah beaver #1
dustin063
how many cold cranking amps do i need i have to get new battery tractor wong turn over fast enough in this cold weather it has a small lawn battery in it now thats what was in it when i bought it 2 cl 15 hp
   / sotah beaver #2
Get as many CCA as will fit in the battery tray. The 2 cylinder has a history of hard starts in the cold. Get a block heater too for one of the freeze plugs. Make sure the glow plugs are working too.
   / sotah beaver
thanks alot i wasnt sure if i got a big one if it would screw something up thanks
   / sotah beaver #4
I use a group 51 for both of my 3 bangers.
   / sotah beaver #5
Do yourself a favor and put Mobil "1" in the crankcase!!! I can't afford to use it in my car, but for only a quart to quart-and a half, you won't believe the cranking speed difference in cold weather!! ~Scotty
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
ASCO Transfer Switch (A52377)
ASCO Transfer...
