Backhoe Soource for grease zerks for B H
   / Soource for grease zerks for B H #1
ron45
N.M.
Kioti LK3054XS
My hoe is mod. KB2376 serial #50228436
I need some grease fittings. I'm assuming these are metric I had a brass one on the pivot pin of the bucket and part of the mating surface is missing. Probably from clearing snow and backing up the steep bank to turn around. I probably ran it into to a rock. I'm fairly sure they don't put them where digging will harm them. The part shaped like a bolt head is 10mm. I was told by someone that if that size wrench fits it the threads are 8mm. Is that correct. I never know how to describe these things to parts places. If anyone knows the numbers for the other fittings on the hoe or the bucket I love to know where to find this out.
One parts wizzard suggested tapping all the holes to SAE. On the surface maybe but wouldn't you have to disassemble each place you did that and remove the metal shavings? Magnet? mabye but how would you know you got them all. I going on the assumption that matters.
   / Soource for grease zerks for B H #2
Kioti dealers. They're a special thread, can be bought elsewhere, BUT NOT readily available. They are referred to as grease zerks. Don't drill/tap to anything else- colossal waste of time, and yes you would need to get all metal out of the pathway/hole.
Hello thank you. Did you put this grease zerk on a Kioti back hoe? The threads in the picture in your link look too coarse to work on my B.H.
   / Soource for grease zerks for B H #5
I used two or three so far. The picture may not be accurate but I think that's the correct number. I'd buy them from the dealer but he didn't have and he's 25-30 min away. I can dbl-ck the package for the part # tomorrow cuz they are in the tool box on the tractor.
Deere 331G (A50120)
Deere 331G (A50120)
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
