crystallattice
Hi,
As the title suggests I'm thinking of mounting a Kelley 55 cat2/3 backhoe to a MF65 cat1
I already have the tractor and trying to make it more useful by adding a backhoe to do trenching for foundations. The option to buy the backhoe came across my path and I'm considering it. First choice was to build backhoe but that will require more time experimenting than using so I'm considering buying one.
The two problems I forsee with the oversized backhoe:
3pt needs enough lifting power to be able for tractor to move it around. The Kelley 55 seems to weigh about 1600lbs, the MF65 can lift around 2000lbs if I'm not mistaken - please correct me as I can't find the source to that to double check.
It seems a backhoe places a lot of stress on top link connection. The Kelley manual states that the pin must be at least 1"
The Mf65 has another stationery top link attachment point a few inches under the draft link on the differential housing. I was thinking of making a type of linkage that will allow the bh to connect to both of those points so as to spread the load between them.
Alternatively I must make a type of subframe to either replace or supplement the 3pt hitch mounting points.
Any ideas, recommendations or suggestions?
