someone please help!!!!!!!
   / someone please help!!!!!!! #1
jmp01454
B 2620
i can not figure out for the life of me what what kind of box blade and rm snow blower to get for my new l3240 or 3400 have not decided on the unit yet please through some ideas out there for me thanks a bunch
jmp
   / someone please help!!!!!!! #2
Box blade-6 footer would be appropriate,like a Woods GB72 or Landpride 2572? Rear snowblower,also a 6 footer,many brands available. Used could be a good option. Good Luck!
   / someone please help!!!!!!! #3
I'd be buying a power turn for it! Don't know what you might get for snow but if you look at a four blade impeller unit they normally blow better.
If you have a gravel drive run with the top link short so it runs on the heel.. If it is paved be sure that there is a cutting edge on the bottom and run the top link a little long!
For width's 72" works as a good width for both tools and an inch or two wider is still safe for operating.
   / someone please help!!!!!!! #4
I would love to have a RM Blower that faced forward myself. It doesn't appear that there any that would fit my BX25 but your tractor may be large enough for one. As mentioned, and manual chute would be a PITA.
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
