some hydrolic work and some stopped
   / some hydrolic work and some stopped #1
jzkobota
Eldersburg, Md.
Kobota
Hydraulic help please. My FEL bucket works both ways and up but will not lower. My out riggers stopped both directions backhoe moves only to the right ( facing rear). Backhoe will not raise. It started when I bumped the out rigger against a stump but nothing seems to be bent. Lines seem ok. The hydraulic fluid was low and I filled it as needed. Any help will be appreciated. Joe from Eldersburg Md
   / some hydrolic work and some stopped #2
Install a hyd gage and check for correct pressure.
Are you sure you have all hoses connected correctly.
Are all QD working correctly?
Is your FEL valve returning to center when you release the handle.
If the pump is turning, the fluid is flowing through all valves, and the lever redirects the fluid where it is needed.
Check BH relief valve for stuck open relief valve.
Remove some hoses to check for flow.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52705)
2007 JLG SKYPOWER...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
