SOme comparisons of the 1430 and 1845?
   / SOme comparisons of the 1430 and 1845? #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
How much larger if at all is the 1845 than the 1430?
Also, what about power? Has anyone drive a 425 and a 1430 and can tell me how much of a dirrerence in power there was with the 1430?
   / SOme comparisons of the 1430 and 1845? #2
I went to PT to buy a 1430, and got an 1845 instead. On aoccasion, I wish I'd gotten an 1850, but the 1845 has done everything I've needed. There are some jobs that require bigger machines, and some where the bigger ones are faster. There are few machines more flexible and capable than a 425, however, and those jobs it can't do are far outnumbered by the ones for which its maneuverability and astonishing lifting power suit it.
The 1430 is bigger than the 425, the 1845 is bigger than the 1430, the 1445 is bigger than the 1845, and the 1460 is bigger yet. As you go bigger, you give away maneuverability and the ability, for instance, to go through narrow gates. You gain power and, as weight increases, pulling ability and lifting capacity. Unless you identify particular projects, I can't say what machine is "better."
I have a Deutz diesel on mine, which is superb. I have a bunch of gasoline machines, including a Kohler or two, and I do not believe that diesel is generally better, just because it's diesel. I have a gasoline engine in a boat that is now about 16 years old, with maybe 2500 hard but intermittent hours on it which has never missed a lick. Even if diesels last longer, which is always debatable, I won't. Diesels are more expensive, noisier, smellier, but the one in my 1845 is a gem. (I also like gas turbines, but don't have any at present. /forums/images/graemlins/grin.gif)
I'll be happy to demonstrate my 1845 to anyone who gets to Maryland. If you want comparisons, Tazewell is a good trip, particularly now, with the fall colors, and you can drive everything they have, dig holes, push dirt, and look through one of the better toy, er , equipment warehouses you'll find.
   / SOme comparisons of the 1430 and 1845? #3
I also have an 1845 and will just add my $.02 to Charlies comments on the topic of Brakes.
The 1430 is like the smaller units in that it has a pin-type Parking brake as the only thing other than the hydraulic drive. You must be fully stopped in order to apply the parking brake which will then keep the machine from rolling away. You can think of it as like the Park function on an automatic trasmission.
The 1445 and larger machines (except 1845 & 1850) have a wet-disc fail-safe type brake which is mainly a parking brake, but will aslo function as an emergency brake to bring you to a stop should the need arrise.
The 1845 and 1850 "slope mower" series has the BrakeTender fail-safe system developed and MSHA approved for mining machinery. It has larger brake discs and the easy built-in ability to be manually released if a disabled machine needs to be towed.
In my opinion, the internal wet-disc system would be my minimum requirement for opperation on any significant slopes. Many folks here have used the 180 through 1430 machines for many years on various terrain with no problems however.
Others have different stories to tell (research the archives here to find them). I have not heard of any run-aways with either the wet-disc or BrakeTender systems however.
Just another aspect to consider in your choice of machines. I have a standard CUT but bought a PT-1845 specifically for rough steep slope (over 30 degrees) work and have been quite pleased with it.
My only problem with this is the affordability. I was starting out looking at a 425 and although a little under powered, I like that unit, but when we start to get up over 18-20k without attachments, man, that's a ton of money. Remember, I'm moving from a Ventrac 4200.
I understand your points though. I was looking on their site and kept going to the next model up... next model up... next model up... phew!!
Reality will set in somewhere and I will figure it out. I really appreciate the feedback on here though.
   / SOme comparisons of the 1430 and 1845? #5
When I was tractor shopping I first got a real good handle on the jobs I needed to do today and the jobs I expected to do in several years.
Then I had to decide what size tractor would do those jobs and relate that to my wallet. Sure, a larger tractor would get the big jobs done much faster, but then I wouldn't need the large jobs done after that, and the large tractor would not be able to mow my lawn and do the small jobs in several years. So we bought a used big tractor loader, did the big jobs with it and plan to get rid of it. The PT425 was bought to do all the day-to-day chores around a home and it does then extremely well. A larger unit, as Charlie was speaking of, is great if you have large jobs to do and large acreage jobs to deal with. We have large acreage, but small acreage jobs like mowing trails and a lawn and plowing a driveway. We have few fields to mow regularly, no crops to plant, etc... I can not afford to have a dedicated machine for each task. I would like to, but I have kids that I need to start putting through college in 7 more years. /forums/images/graemlins/wink.gif
It's a struggle to make the choice for sure. I know that I can not afford $20K for just the tractor. My choice really rests between the 1430 and the 425. I was talking to Scott at PT today, (what nice people!), and the 1430 is about 10" longer than the 425, but weighs around 1000 lbs more. It does have a wider stance and a version of weight transfer when using the mower.
He told me that the 1430 will have more power going up a hill than the 425 when mowing, but of course, not like an 1845.
If I get the 1430, I will not be able to afford much more than the mower, bucket and front end hoe.
If I get the 425, I could literally buy $5k worth of toys before I start to tap into my reserve funds.
Man, if they would just put a more powerful engine in the 425!!
I asked him if they had considered the Vanguard gas 31 hp, or Diesel that is in the Ventrac and he had not heard of it. That is a pretty small engine??
   / SOme comparisons of the 1430 and 1845? #7
I understand how you're feeling. The 425 chassis is the perfect size. I'm happy with the power, but more power... aaaruuuh!!!??? Where's Tim the Tool Man Taylor when you need him??? /forums/images/graemlins/grin.gif
   / SOme comparisons of the 1430 and 1845? #8
Jim,
I fully understand that total cost has to figure into everyones consideration of what they want versus what they can afford. In my case I started seriously consdering the 1430 and ended up with a used 1845.
My point in explaining the different brake systems was to point out a significant difference between models that may not be so evident in looking over the various specs. You are obviously trying to do your homework in researching all the options, and what ever decision you make will at least be an informed one.
All the PTs are certainly good strong versitile machines and will do a lot of work for many years. They are also inherently very stable on hills, especially compared to any brand or type of CUT.
Good luck, Rip
   / SOme comparisons of the 1430 and 1845? #9
"" He told me that the 1430 will have more power going up a hill than the 425 ""
/forums/images/graemlins/confused.gif The PT-1430 weighs about 65% more than a PT-425, but only has 20% more HP!!!! /forums/images/graemlins/confused.gif
/forums/images/graemlins/confused.gif Like a truck with 300 HP compared to a sports car with 'only' 250??!!?? /forums/images/graemlins/confused.gif
I don't think you can just look at the weight.
Some of the thoughts I might have about that are:
How much more torque does the 30hp diesel have than the 25hp gas?
What weel motors are being used on the 1430 vs the 425?
What is the Hydraulic flow rate to the motors on the 1430 vs the 425?
You guys are probably more knowledgeable in these areas, but I would consider more than just weight when comparing the two.
thoughts?
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
