Some clarification please
/ Some clarification please #1
Proletarian
Bronze Member
North of Atlanta
BX-25 / BX-1830
should I be running an "over running" PTO clutch adapter on my rear PTO on my BX-25 for tilling
or does it have an internal one, or does it need it at all? :confused:
thanks in advance
/ Some clarification please #2
With little or no centrifugal force developed using a roto tiller, you should not need a overrun clutch. Slip clutch is very nice option to have on a tiller. Ken Sweet
/ Some clarification please #3
It's not like you going to try starting the tiller in/on the ground first. Start it up before lowering it and then slowly drop 3 pt and go to work. I have a slip clutch on mine due to rocks or tree roots/wild grape vines that was on my virgin ground . I dont need it anymore now but its a peace of mind to know slip clutch is there to save my BX pto.
/ Some clarification please #4
I used an external overrunning clutch on PTO's linked to travel speed, such as our old 8N Ford. A bush hog can drive the tractor forward without an overrunning clutch in such a case. Your BX is completely independent of ground speed, so I don't think it would be a problem.
Some PTO's do have internal breaking to stop the PTO shaft when disengaged, and that break cannot stop a great deal of inertia effectively, so I always try to disengage in a fully throttled down state.
thanks for the replies. I had simply never heard of an over run cluth and was unclear of its use. wanted to be sure, dont wanna break anything.
John Deere HX15 Batwing Mower (A64047)
John Deere HX15...
1059 (A63291)
1059 (A63291)
11R22.5 ALUMINUM WHEELS AND TIRES (A63569)
11R22.5 ALUMINUM...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2012 HEIL 200BBL CRUDE TRAILER W/ PUMP (A63569)
2012 HEIL 200BBL...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
