Solved: Branson power steering connections
   / Solved: Branson power steering connections #1
kw00
Branson 2400
Have forgotten which connections go where on the power steering valve. Connections are labeled P T L R. L and R are obvious. Is P for pressure? What the heck does T mean? If it were S or D I would be more confident. The T connections comes out of the center.
   / Solved: Branson power steering connections #2
P is pressure, T is tank. T usually goes to Tank or the Transmission housing on tractors. However, on the hydrostatic models, the power steering pump is also the charge pump for the hydrostatic transmission.
If yours is a gear driven, then it goes to the transmission housing. If it's an hydrostatic model, it goes to the hydrostatic pump.
Thanks! That's what I needed.
434669 (A48836)
434669 (A48836)
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A54313)
2012 INTERNATIONAL...
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
