solenoid problem?
   / solenoid problem? #1
ragman
Bronze Member
Green Garden,Illinois
BX22 TLB
I have a L4200GST. Well, actually its my neighbors, but I use it more than him! I always stop the engine by just turning the key off, and it stops. Today I went to turn it off and it kept running. Had to stop it by using the stop pull cable on the dashboard. Could I have a bad solenoid? Broken wire? etc. I had been starting and stopping it all day by the key. All of the sudden this happened. Solenoid doesn't work at all. Anybody out there had this come up before?
   / solenoid problem? #2
just had a simular problem only engine would not start. there is a 15Amp fuse or a timer defective,or the fuel cut off solenoid is defective. my problem was trash keeping the solenoid from inguaging. also the electrical system prints suggests possible loose wiring going to switch.
se'ya ken
   / solenoid problem? #3
I had to replace the fuel shut off solenoid on my L4150, located on the firewall behind the dash. Check that perhaps.
23169 (A50324)
23169 (A50324)
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
Unused Delta Crash...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
