m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 3,701
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
Talked to the dealer about where to hook up the hydraulic winch and he showed me where there is a short hose that continues from the FEL valve back to the three point valve on the right lower side of the tractor. He recommended to take this hose off and install the new spool valve in that loop with two new hoses that can handle the full flow ( 1/2 inch ) and then run hoses out to the winch from there.
So next i want to locate an electric operated spool valve that can handle the flow of the tractor in the open position ( about 11 gpm ) and be adjustable via relief valve to 1500 psi as this is what Milemarker recommends. That way I can plug in with a cable to run it at a safe distance from the winch.
Now I looked at the Surplus Center catalog and found a Gresen valve that seems to fit the bill. It is Item 9-1625 (spool valve) on page 14 and Item 9-1625R which is the adjustable relief valve section. Anyone done this before and will this work?
