Solar fence charger wiring question
   / Solar fence charger wiring question #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I will be installing a new gate in a section of electric horse fencing and will need to pass a wire underground to maintain the electrical connection between the 2 sections. Can I used heavy duty low voltage landscaping wire for the connection? The fence is powered by a 5,000 volt solar charger. I think it's 3 joules. Not sure if the charger will fry the wire.
   / Solar fence charger wiring question #4
I also use the underground rated wire specifically for electric fences. Although I don't remember the reason, if what you were trying to use is a stranded wire that is a no-no for any connection of an electric fence.
   / Solar fence charger wiring question #5
The wire needs to be shielded because of how important ground is for it to work properly. You can buy shielded wire designed for this, or you can use coaxial cable used for TV's.
Eddie
   / Solar fence charger wiring question #6
I would put the specially insulated wire sold for this purpose inside a 1/2" conduit and seal so no moisture/water can get in. The high tension electricity will ground out easy if immersed in water. Better safe than sorry.
ron
   / Solar fence charger wiring question #7
I would put the specially insulated wire sold for this purpose inside a 1/2" conduit and seal so no moisture/water can get in. The high tension electricity will ground out easy if immersed in water. Better safe than sorry. ron
I have 30+ (got tired of counting) underground electric fence connections, with more than half of those being over 10 years old. Conduit is overkill.
The underground rated wire coating is very robust. As long as you aren't back filling the ditch with rocks it will be fine. In fact I have one new gate crossing, using underground wire, that I haven't found the time to bury yet. We have been driving over the exposed wire since February. I need to bury it but for now it's still working fine.
Thanks for the replies. The low voltage wire I have is stranded so that's a no go. I am using Horseguard's Bi-Polar fencing - no grounding required. Great product.
   / Solar fence charger wiring question #10
I have 30+ (got tired of counting) underground electric fence connections, with more than half of those being over 10 years old. Conduit is overkill. The underground rated wire coating is very robust. As long as you aren't back filling the ditch with rocks it will be fine. In fact I have one new gate crossing, using underground wire, that I haven't found the time to bury yet. We have been driving over the exposed wire since February. I need to bury it but for now it's still working fine.
I'm glad you've had good luck without the conduit. But the best I could do was two years. Now everything goes in conduit. I don't seal it but bring it up a few inches above ground. Conduit also allows you to only dig the trench once.
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A52576)
1968 CHEVROLET C10...
New/Unused Self Dumping Hopper (A51573)
New/Unused Self...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
