Soil Compaction
   / Soil Compaction #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Why is soil compaction such a concern to farmers?
Does compacted soil make it more difficlt to plant seed?
Does compacted soil make it more difficult for seed to germinate?
There must be a reason for the 8 wheeled beasts.
   / Soil Compaction #2
My idea of soil compaction is what happens just below the few inches which are tilled.
This compaction layer can occur due to the action of the tiller above or due to the weight of heavy vehicles - particularly when wet.
The compacted layer can prevent roots and moisture from penetrating into this subsoil.
   / Soil Compaction #3
Well main reason is to break the ground for drainage. it's better for growth as the roots travel deeper than off the the side, thus this holds the corn up better. while roots go deeper you can have more moisture means better yield. You want to break the ground from below instead of the top for erosion purposes. Now with the 4wds with duals gives better traction and less compaction. Using tracks is even better, hardly any compaction and allows worms to break down the fotter.
   / Soil Compaction #4
if soil is compacted real bad that means that it cant absorb the water deep in the ground.thus causing the water to run off.if you can renovate the soil pretty good it allows the rain an run off to get deeper into the ground.thus storing moisture in the grasses root system.an it also allow the grass roots to spread out an grow better.
   / Soil Compaction #5
Compaction can go down as far as 6 feet in some cases. It totally alters the soil including naturally occuring things like beneficial soil microbes, nematodes, etc. It makes germination difficult, stunts root growth, limits moisture penetration, stops oxygen transfer to the roots, and creates a host of other problems.
There has been a series of articles over the past 3-4 years in the John Deere "The Furrow" magazine detailing measures taken by farmers to limit and deal with compaction. Many farmers are planting second crop of "tillage radishes" that have a single long tap root that breaks up the soil as it grows to naturally aerate the soil and break up the compaction.
This is one of the reasons for the multi-wheel and tracked tractors to lower ground pressure and why tractor pulled grain carts are used instead of allowing the grain transport trucks into the fields during grain harvests.
   / Soil Compaction #7
Our renters routinely run subsoilers on our ground to break up compaction and the people on the next farm have gone to all John Deere tracked machines.
   / Soil Compaction #8
I know the man who farms the 120 acres around my property, and I inquired about the issue...he told me that in this area where the soil is mainly heavy clay, compaction is a serious issue to growing just about any crop be it corn, soybeans, or sugar beets. During dry spells the clay becomes so hard roots cannot penetrate well and water does not soak into the surface. When I till my garden plot, I routinely dig down as far as the tines will go (about 11") even though the roots of vegetables I grow rarely go below 6"-8". It seems to me that even with poor soil, I have good success with my crop yields if the roots can penetrate. One end of my garden, a 7'X28' area, is only a few years old, and I am still attempting to get the soil broken up in that area to the 11" depth. My harvest in that area is much poorer than the other areas of the garden.
   / Soil Compaction #9
Grew up on clay, now on sand based soil. Sands compact as well!!! It is amazing. As said very well by everyone above, compaction is a horrid thing that suffocates root growth, starves moisture, prevents oxygen/gas exchange, etc, etc. Soil structure is a complex subject, one that I enjoy studying and have found to be a challenging, life long interesting fascination.
   / Soil Compaction #10
Soil compaction prevents the crops root system from its maximum plant support and thus reduces yields. Soil compaction also lends itself to excessive water runoff. Ken Sweet
Lincoln Electric DC-400 Welding Machine (A53117)
Lincoln Electric...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2011 Dodge Nitro SUV (A51694)
2011 Dodge Nitro...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
2016 Nissan Versa SV Sedan (A53117)
2016 Nissan Versa...
