Soft Plug Heaters
   / Soft Plug Heaters #1
DigDug
Spencer, New York
Century 3035
Has anyone had any experience with installing a heater into a hole that used to contain a soft plug? My dealer is recommending this as an alternative to a hose installed in the lower radiator hose.
   / Soft Plug Heaters #2
There is a plug on the left side of the engine block that will screw out to accommodate the block heater without removing the freeze plug, I would recommend using the heater supplied by the factory so not to affect the warranty. Good luck
   / Soft Plug Heaters
Thanks for the reply! Is this plug on the Kukje 3T90L motor? I asked my dealer and he said that they don't have a factory heater for it? He has been wrong before......
   / Soft Plug Heaters #4
<font color="blue"> I would recommend using the heater supplied by the factory so not to affect the warranty. </font>
Just curious, what tractor company will bounce a warranty because of a engine heater?
   / Soft Plug Heaters #5
The plug should be at back (left) side, just pull the wiring out of the way. If you have a Branson dealer near you he will be able to get the recomended heater for you.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
