Socket size for GMC distributor cap???
   / Socket size for GMC distributor cap??? #1
Arc weld
Veteran Member
Edmonton, Alberta
MF 135
I searched everywhere and couldn't find an answer. I need to change the distributor cap and rotor on my 95 GMC Topkick with a 6.0 litre engine. It's in between 3/16" and 1/4" so I'm guessing a 7/32" but could be metric as well. I'm hoping someone on here will know for sure what size of socket or nut driver to get.
   / Socket size for GMC distributor cap??? #2
I'd say get a cheap set of metric nut drivers...Probably less than $20...I think its around 8mm but not 100% sure.
   / Socket size for GMC distributor cap??? #3
7/32 or 5.5mm. Get a six point cause if you round one of those off your vocabulary will expand with a plethora of new four letter word combinations
Thanks, I thought it might be 7/32" or metric equivalent. 8mm is way to big, that's 5/16". Why didn't they just make it a more common 1/4"? The new would work with a Phillips screw driver but the one that's on there a Phillips is useless.
   / Socket size for GMC distributor cap??? #5
it is 7/32
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
