I did have some electric problems at the start, but some new fuses, a diode here and there, a seat switch and a starter and I was off and running. In short order I completed a trail around my 40+ acres. The mass of vines (some 9" in diameter) and the thorns were a challenge for the SR80, and although it has been dry here in Western New York State, the creek/swamp crossing still required every inch of the 20" track system. The machine is smooth, fast and quiet. It rides smoother than my UTV. The Red Dot air conditioning system starts cooling in minutes and makes the cockpit as cold as you like. I was surprised that curl strength is not as good as lift strength, but it handles, albeit with some finesse, grubbing, digging and grading with relative ease. I am still not at full throttle, so after it is broken in a little and I push the revs up, I expect it will have more than adequate power for the work I have lined up. I have driven many of the compact track machines, and none compare to this SR80. I know there is trade off regarding the relatively shorter undercarriage life, but even if this is so, the smooth ride would be worth it. As for the multi link track system I'm not sure what that is, but I do know my track system is the ISR-4 suspension. Well back to the barn, preventive maintenance is daily ritual.
jmf
