snowthrower drive chain on JD455 & 47" blower
   / snowthrower drive chain on JD455 & 47" blower #1
coachgrd
nw PA
Kubota BX1870
snowthrower drive chain on JD455 & 47\" blower
Of course the drive chain on my blower dies today! We just got a foot of snow! And its Sunday!!!
Anyway, I was wondering if any of you have had to replace the drive chain? Is this an ordeal for a DIYer? Can you offer me some advice?
If you've replaced one in the past, do you recall the price of a new drive chain?
Thanks,
coach
   / snowthrower drive chain on JD455 & 47" blower #2
Re: snowthrower drive chain on JD455 & 47\" blower
I took mine apart to lube it this fall. Only had to removed 3 bolts to get at it. Be sure to adjust idler sprocket for proper chain tension. when you put new chain on.
If you have a TSC store close they should have the chain and master links.
As suggested by another TBNer. I am going to drill a hole in the cover that lines up with the chain. Then use this hole to put a few drops of oil on chain after each use.
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
