snowmobile trailer tounge help advice needed,
   / snowmobile trailer tounge help advice needed, #1
escavader
Veteran Member
western maine
bx-23 ,
Hey guys.I want to convert the tounge on my aluminuim snowmobile trailer,so i can use my weight distrubution hitch.I cant weld aluminuim,so i was gonna use steel and bolt it togeather .Heres a pic.I was gonna weld two peices togeather and bolt to the existing hitch.bolt on two peices of plate on the front of the bed.and weld the new v arms to.I hope you are following me ....to make it similar to my tandem trailers nose.Im worryed about touching the two different metals so i was gonna use some gasket material between them.I understand i will be eliminating the tilt feature,but i dont use it much any way,i primarily haul atvs,and take a ramp.
PLEASE GIVE ANY SUGGESTIONS YOU MIGHT HAVE.
ALAN
   / snowmobile trailer tounge help advice needed, #2
Why do you need a weight distribution hitch on a sled trailer? Even with 2 quads on it, you're nowhere near needing one in my opinion. I don't even think the axle will handle over 2500lbs.
   / snowmobile trailer tounge help advice needed, #3
All a weight distribution hitch will do for you is bend that trailer tongue. Bad idea. MikeD74T
Well,i cant seem to find the perfect spot hauling my two large atvs.Im either too far forward and my jeep is down in the rear or just when i think i got the sweet spot i start fish tailing the trailer.It never use to be an issue,but the wifes new wheeler is alot heavyer then mine.I know this sounds crazy,but my 14 ft tandem car hauler seems to haul easier with 3 on it then my 10 ft aluminuim trailer with two.I just cant seem to find the perfect tounge weight,i thought i could mofify it to use the wdh.So id bend my tounge? I was only thinking of a slight weight increase forward,would it then?I guess when you get use to a weight dis.hitch there is no turning back.MABEY i should just use the tandem for trucken them,i just figured the aluminuim trailer had to be lighter by far,it should be better on fuel mileage.We got a 700 mile trip planned ,i need to get max mileage at 3 dollars a gallon:eek:
ALAN
   / snowmobile trailer tounge help advice needed, #5
With a weight equalizing hitch the torsion arms increase the vertical rigidity of the "hinge" at the coupling ball. By pushing/pulling down on the trailer tongue it lifts the rear of the tow vehicle transferring some the force thru the tow vehicle's frame to it's front wheels. One of the hitch manufacturers used to advertize the hitch's effectiveness by adjusting the hitch between a trailer & an Olds Toronado (front wheel drive), removing the Olds' rear wheels, and the tongue would hold the rear of the car off the ground. Your idea might work most of the time but an incline like entering steep driveway could overload the tongue to the point of failure. I'd go with the heavier trailer for the trip. A failure away from home is never cheap. You might also consider converting that trailer to dual axle if you're carrying 4 wheelers a lot. They just balance a lot better. Mike D74T
   / snowmobile trailer tounge help advice needed, #6
If trailer was wide enough, you could load them sideways instead, the atv trailers load from left or right side with ramps, don't know if that would distribute weight better. We hauled four machines on car trailer and had to load them sideways, because of fenders. The tongue you described building, is called a wishbone tongue, some snowmobile trailers have them. I have a straight tongue on my snowmobile trailer similiar to yours, it is double walled, because single walled tongues are known to bend or break from road salt and fatigue. plowking
   / snowmobile trailer tounge help advice needed, #7
Escavader, I just reread your original post. I'd missed your intention to rework the tongue. The "duh" in my head seems to be in charge today. You can make the weight equalizer work if you make the tongue strong enough to hold up the back of the Jeep. Seems like the cost of that alone would buy a lot of gas. MikeD74T
MIKE,
I THINK I can get the pieces at work and fab at home.Its steel though and the trailer is aluminuim,so ill have to
1] bolt the stuff togeather ,probably with stainless steel bolts
2] use some sort of gasket between the metals.
I was thinking the two outside angled piecesof this"wishbone"[thank you PLOW KING]ill cut the ends at the proper angle[45 mabey] and weld some plates on with holes drilled in them so they can be bolted to the tounge,and the other end to the trailer body.Do you guys think a couple 1/2 holes will weaken the tounge,as long is they are not directly over each other?SO really its only two 5 fters and 4 little pieces of plate ,and some bolts.
Ihave found myself even in the winter hauling just my own sled,wanting the weight dis.hitch on.When i put the aluminuim hinged cover on ii the winter,i dont have much leway of where to put the sled,especially if im also hauling my buddys longtrack.
Any advice on minimum size on the frame work[or any thing else] would be appreciated.I think the tounge now is like 4by 4 if i had to guess.Its also possible to fab it,so i use u bolts to hold the outside supports to the tounge,instead of drilling it .
I just feel the only other option i have is tow this trailer with something else,or add some springs to the jeep so i can have more tounge weight,and that would be costly.Some of you know im buying a new truck,but ill probably still use the jeep in the winter,to keep my new rig out of this darn road salt up here.
ALAN
   / snowmobile trailer tounge help advice needed, #9
I would get the leaf springs beefed up a little, or consider an airbag system in the jeep. It can be done cheaply (springs are around 200 installed) or with Airbags (around 500, you install)
I've had airbags before and they worked well, although I would try the springs before I went with a set of bags.
   / snowmobile trailer tounge help advice needed, #10
escavader
You want a sway bar to help prevent fish tailing
DrawTite-Hitches.com
3400 series
you might have a problem with the side wall stiffness on your tires
tommu56
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
1997 East Manufacturing Walking-Floor Trailer, VIN # 1E1U1X287VRE22897 (A51572)
1997 East...
2011 Ford Crown Victoria Passenger Car (A51694)
2011 Ford Crown...
