Snowmobile track studding
   / Snowmobile track studding #1
lawnduster
Bronze Member
Central NH
CAT 966, Case 580
my '05 Ski-doo Gsx 380 fan's track says DO NOT STUD on it. Anybody know why or if it really means anything? I was going to stud it this year but was curious about this warning before I stud it.
   / Snowmobile track studding #2
Call your dealer. I have 2 sleds and never needed to stud them but I don't get out on frozen lakes very often.
I've only seen even with a 380 that you could only put 48 picks on it anyway. It's not a hp issue because it doesn't have much to begin with.
   / Snowmobile track studding #3
Late reply but my .02 says there may be an obstruction under the tunnel. I.e., my old Yamaha liquid Exciter had an oil cooler that hung down slightly, just enough to interfere with the longer pics. The solution if you rode on ice was to install suspension 'blocks' to limit suspension travel, in conjunction with shorter style v-studs instead of the long pics. With the suspension cranked to the stiffest setting, I never bottomed out with that setup and I could lift the front end no problem! Worth checking on...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
