Snowblowing with snowmobile helmet
   / Snowblowing with snowmobile helmet #1
doxford jim
Veteran Member
British Columbia, Canada
1959 MF-65 sold, 2007 Jinma 554 diesel.
Hi Guys,
Today I used the tractor for the first time this winter to blow snow with - pto blower, open station. The weather was perfect at around 20F and no wind at all !!!
I found it so much better today and it got me wondering about using a snowmobile helmet when blowing snow - I can see lots of benefits from it.
I have had to blow snow at 10F and windy conditions and it ain't fun.
Sooo, how many of you use a helmet to keep the elements at bay while blowing snow ? How bad is the misting of the face shield ?
It is the cold wind and the freezing snow around the head that gets me - even when bundled up. Thought the skidoo helmet would be a great help - your thoughts please.
   / Snowblowing with snowmobile helmet #2
I have a big yard, mile long gravel driveway and mail box areas to clear. When I had a smaller tractor I had a blower. I never thought of wearing my motorcycle helmet. I wore a stocking hat and pulled the hood of my down parka over that. I believe if you have a full face helmet - blowing snow on the face shield from the outside and your breath condensing on the inside might be a real problem.
My full face MC helmet relies, to a great extent, on my going fast enough for the wind to keep the face shield cleared of condensing breath on the inside. Never rode the MC in a snow storm - and I never will.
And I now have a much bigger tractor and use a rear blade rather than a blower. Seemed that the blower always had blowing snow drifting back on me, no matter which way the chute was turned.
   / Snowblowing with snowmobile helmet #3
When I had a snow blower and it was windy, I'd use a full face ski knit mask (bank robber style) and ski goggles. Worked great. I used to wear that same combination when ice fishing in windy weather, too. :thumbsup:
   / Snowblowing with snowmobile helmet #4
I would think that MossRoad's suggestion is a far better answer to your situation. If you need additional warmth - get a jacket with a hood and pull that up and over the ski mask.
   / Snowblowing with snowmobile helmet #5
When I used my snowblower with an open station tractor, I wore a "Mad Bomber" hat and ski goggles (tinted ones are the best and if you wear glasses, get goggles that are made for wearing glasses).
As far as helmets, there are a number of TBNer who do wear snowmobile gear (including the helmets) when clearing snow.
Unless you have a cab tractor (which I do now), getting covered with snow is an occasional certainty when using a snow blower.
   / Snowblowing with snowmobile helmet #6
I have a front blade and have been using a MC helmet for years. it works well for me but you do have to crack the visor open a little to clear the fog. Don't know how it would work with a blower. Goggles might work better, might pull out the off road helmet and goggles I had for the 4 wheeler and give it try this year, if we get any snow. Ed
   / Snowblowing with snowmobile helmet #7
Ski goggles tend to stay fairly clear. Works well with a Mountain Hardwear jacket. The hood closes up around your face and googles.
   / Snowblowing with snowmobile helmet #8
Snowmobile helmets are warmer and don't get wet. I used to use a full face helmet and leave visor up much of the time, putting it down when needed (going upwind). Many have a "breath deflector" nose shield that minimizes any fogging. Leave visor up after any physical exertion eg getting off to shovel etc. Keep any vents open. A snowmobile specific helmet will be better designed for this than a motorcycle one.
I now have luxury of a cab and front blower. One thing with new blower I only now realize is the value of powered deflection. Being able to keep the plume down most of the time keeps the blowing snow to a minimum. Had rotation but not deflection on the open station unit.
   / Snowblowing with snowmobile helmet #9
In the past motorcycle helmet with visor cracked open very slightly worked well, warm and no problems with visor steaming up.
   / Snowblowing with snowmobile helmet #10
Snowmobile helmet with heated visor eliminates fogging. I call the snowmobile helmet my poor mans cab!
2010 New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
2010 New Holland...
Chery Q.A 66" Rock Bucket (A50121)
Chery Q.A 66" Rock...
2013 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2013 Ford F-450...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
Kubota BX22 TLB Compact Tractor (RUNS) (A50774)
Kubota BX22 TLB...
