Snowblower snowblower
   / snowblower #1
kramarj
Durand, Illinois
Kubota B7100 w/1630C Loader
is it possible to take a front mount snowblower and convert it over to a 3 point mounted snowblower
   / snowblower #2
Anything is possible with enough inginuity and money. One thing to check is the direction of PTO rotation as well as the speed of the PTOs.
   / snowblower #3
Why not consider selling the front mount blower which traditionally sells at more then twice the cost of new rear units. Go buy a new rear unit and buy take a few bucks to the savings bank perhaps.
rim
   / snowblower
i have a kubota b7100 with a loader and i dont want to take the loader off, and i dont have a lot of money to spend on one, plus i only will use it a few times a year
   / snowblower #6
If I didn't get a lot of snow, I guess I could understand what you are doing, but the front mounted blower is great for snow removal if, like me, you will spend many hours at it on may different occassions, and the snow comes and stays for several months at a time. Today I went out and blew about 5" of fresh low moisture content snow. It only takes about 35 minutes from start to putting it away, because I can cruise quite fast looking forward.
Right now, in my own case, I have no need for a FEL I haven't seen the ground since Thanksgiving. Once the snow is gone then I will switch the blower out and put on the FEL.
   / snowblower #7
Yep! My first thought was that the quick and easy way of just putting on some 3 point attachment lugs and connecting it up. Then fire it up and watch it make snow, vice removing it. :)
Harry K
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
71050 (A49346)
71050 (A49346)
2021 TAKEUCHI TL8R2 SKID STEER (A51242)
2021 TAKEUCHI...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
