Snowblower size?
   / Snowblower size? #1
Canada_CT230
Platinum Member
Nowhere
1878 Ford 65N
I have a new Bobcat CT230 and it is a 30 HP tractor. I've been looking at some snowblowers and I have come across a few good deals but they are larger (72" or bigger). I was thinking a 60" personally but not sure how much HP is required for each size. Any ideas?
   / Snowblower size? #2
I would get the 72" blower. Move a lot more snow faster. I know your tractor can handle it.
   / Snowblower size? #3
You want a blower that is wider than your wheeltrack so you don't drive over snow and pack it down. A wider blower is going to be more awkward in tight spots, but I think wider is better because you can do fewer passes if the snow isn't taxing the tractor engine. If it is tax your tracor, make your 72" blower a narrower blower by taking smaller cuts after the first pass. If the snow is deep, or heavy just go really, really slow on the first pass.
   / Snowblower size?
Yes on covering tracks. A 60" will cover my tracks. I was worried about HP to drive the unit but figured if you drove slower it would chew sufficiently.
Normally we get 4-6" at a time. If it was a monster snow fall then maybe 1 - 1.5 feet but I could always go out twice.
I just wanted to make sure I wasn't passing up a good deal just to hold out for a 60" model.
   / Snowblower size? #5
Yeah, it will definatly have enough PTO HP.
   / Snowblower size? #6
I run a six foot on my 28Hp -- not an issue:eek:
   / Snowblower size? #7
I have a 66" farm king with my ct225 (27hp ) No problems handling fresh snow.
   / Snowblower size? #9
welcome to tbn, canada. i have traction was an issue trying to push too large a snowblower with a 2wd, a quick glance at photos makes it look like a ct230 is 4wd? We push a 84" with 55hp and I can still bog down and blow shear pins. Like the others have said, sometimes just take it slower and/or take a narrower slice, I'm sure you could make do with the larger blower.
Brent
   / Snowblower size? #10
Usually, you should see the HP requirement in the manufacturer specs.
You can have 2 blowers with the same width requiring different min./max. HP based on fan size, weight and so on.
I would go slightly larger than your tractor, just enough to give you a certain maneuverability while you turn and blow at the same time. It could probably take allot larger but I don't think it would be to your advantage.
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
Bef-Co Finish Mower - INOPERABLE/PARTS ONLY (A52128)
Bef-Co Finish...
New Holland B95 Backhoe (A50490)
New Holland B95...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
Tires (A50322)
Tires (A50322)
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
