Snowblower size?
   / Snowblower size? #1
855Idiot
Bronze Member
Salt Lake City, Utah
John Deere 855
I have seen several local ads for affordable used rear snowblowers for tractors.
I don't know what size my tractor will handle?
My JD 855 is rated at 24 horse and 19 at the pto according to tractordata.com
TractorData.com - John Deere 855 tractor data
Is there a rule of thumb for snowblower size and horsepower?
What do you need to look for to keep out of trouble when buying a used one?
Thanks,
Glenn
   / Snowblower size? #2
Glenn -
You're probably looking at 48"-60". I wouldn't go bigger than that. Make sure
it's wider than your tractor. :)
Bearings, gearbox, chain, PTO shaft would all be things to be looked at and evaluated.
Scott
   / Snowblower size? #3
From my expierence, I'd stick with a 48"-60" to.
:D :D
   / Snowblower size? #4
Glenn The rule of thumb is 5 hp. per foot of blower. I had a 54" blower on a small Ford tractor with only 13 Pto hp. and it worked well. Garry:)
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A55788)
2008 Ford F-250...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2004 CATERPILLAR 420D IT BACKHOE (A51406)
2004 CATERPILLAR...
Adams 8 Ton Weigh Hopper (A55301)
Adams 8 Ton Weigh...
