snowblower shear bolts on a 2210
   / snowblower shear bolts on a 2210 #1
gsk99
I seem to be breaking a lot of shear bolts on the second stage of a 47" snowblower attached to my JD2210. The original seemed to last quite a while. I have a lot of gravel around so I expect to break some but I don't expect to be breaking so many bolts compared to how long the original lasted. The bolts are supplied by my local JD dealer. What grade bolt should this blower be using? Is there something else I should check? Everything seems to be turning just fine.
   / snowblower shear bolts on a 2210 #2
Check the tightness of the two allen head screws in the second stage- if that part is loose you will break shear bolts all day- also be sure your drive shafts are aligned properly- there was a thread about this in 2006 I think. I took care of these two things and have not lost a shear bolt yet.
United 5' 3pt. Box Blade (A50775)
United 5' 3pt. Box...
New/Unused Gold Mountain Container Shelter 30ft x 65ft x15ft (A54865)
New/Unused Gold...
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
Agco 1328 3pt. Disc Mower (A50775)
Agco 1328 3pt...
John Deere 7130 (A53314)
John Deere 7130...
CFG Industrial XZ20R (A53316)
CFG Industrial...
