Snowblower snowblower refurb
   / snowblower refurb #1
doggggboy
Saskatchewan, Canada
Ford 1710
I have a 6 foot Lucknow I use on the front of my skidsteer. It is very old and very used but still works very well. The only thing is that there is about 1/2 to 3/4 inch clearance between the impeller blades and the housing. I am thinking that it would work much better if that clearance were much less, like the maybe the thickness of a dime. I think I have 2 options. I could pull the impeller off and weld a bead on the end of the blades to get the extra length or I could line the inside of the housing with something. I am leaning towards relining the housing as this is the part that seems to have worn, not the blades. Any ideas?
   / snowblower refurb #2
I think it would be cheaper and faster to weld a bead on each blade. Getting something to stay in place to line it would be more of a job. V
   / snowblower refurb #3
I know there has been plenty of discussion here about impeller-to-housing clearance. Do a search and you'll find plenty to read. I'm not sure i buy into it yet......... when its blowing snow, wouldn't the housing be covered in snow effectively making the gap zero??
   / snowblower refurb #4
If the housing has worn 1/4 - 1/2" evenly, all the way around since new, it was amazingly thick to begin with. I would extend the impeller blades, of the two choices. if you weld, it should be fairly easy. I would also try to get it roughly balanced when done.
   / snowblower refurb #5
I'm with you duc. This whole crazy theory needs to make it on to Mythbusters so we can put it to bed once and for all.
KB
   / snowblower refurb #7
I like the rubber pad idea BigDogue posted. That way the rubber can butt right up to the housing and will "burn in" on the first run, thus giving a good seal.
Or, instead of welding a "bead" to the tips of the fan blades, how about weld a piece of flat stock, all the way across? Use a piece of sheet metal as a feeler guage/shim to find the proper distance between the housing and fan blade, as you will still want some gap as a margin for safety.
Danuser Digger F-8 (A52128)
Danuser Digger F-8...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2012 Ford F-150 FX2 (A50323)
2012 Ford F-150...
