snowblower problems auger
   / snowblower problems auger #1
habber
Miramichi NB
Massey GC2400
I just bought a new Puma snowblower yesterday to put on my MF gc2400. I used it tonight for the first time, I used it for about 20 min. Then I stopped it to talk to buddy next door. When I got back in the tractor the blower would not work but the PTO would work but the blower would not. So I got out to check to see what the problems was...I spun the auger by hand and then it just siezed up and has not moved since. I did notice that a sheer pin was broke but this should have nothing to do with the frozen auger. Your help would be appreciated.
t
   / snowblower problems auger #2
Might have bent something when the shear pin let go.
Just a comment. When I bought mine new I went through PTO shear bolts every snow storm. I finally put in a hardened bolt ( big no no ) they are only 1/4" diam and have run like that for 8 years. Just for ha, ha I put in a grade 2 bolt ( soft) this year to see what will happan.
The difference is I used to work and plowed at night when I got home, so middle of the night was a bad time for repairs. Now I am retired and I plow when I feel like getting up in the morning. Not that this helps with your problem, of course.
   / snowblower problems auger #4
Our Farm King calls for a Gr 8 bolt. Why is the hard bolt a no no??
It depends on how the blower was engineered. They are all different. Mine for example calls for a 5/16x1 3/4" grade 5. But some call for grade 8 and some for grade 2. My little blower even has a bolt that is cut have way through it to start with, just to make sure it shears. They are engineered to protect the blower and it's parts. You should never put in a harder bolt than what the blower was engineered for. Unless you are willing to accept the consequences.
   / snowblower problems auger #5
Does it have a gearbox? If so, has the oil been checked?
   / snowblower problems auger #6
I don't know much about snow blowers, but are you engaging the pto with the engine rpm low, then raising the rpm up, or engaging it when the rpm is up. Would the jolt of engaging at rpm be enough to cause the sheer pin to sheer?
   / snowblower problems auger #7
I think it is more sticks in the auger or stones in the blower.
Although I never found anything in mine when the shear bolt let go. Thats why I put a stronger one in.
   / snowblower problems auger #8
have you checked to see if there's ice in the bottom?
O.K, I put a new shear pin in and started up the blower...it broke the pin but the auger unsiezed. Everytime I put a new shear pin in it breaks as soon as I start up the blower???? I went through 3 pins before I quit.
t
   / snowblower problems auger #10
This would get my vote. Takes a surprisingly small amount of snow to melt, collect on the bottom of the second stage, and freeze. The impeller isn't going anywhere. Look at the bottom and see if some snow melted and re froze. (Also good practice to prevent/detect this is to move the impellar with your hand each time BEFORE you fire up the tractor. It should move freely.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
