jrogers
Bronze Member
Ok, so I made it thought my initial teething pains with the new tractor (B2630) and snowblower (63 front mount) and all seems to be working well now. Thanks for all of the help and advice I received here! Now that I am running, I just had a few questions so that I don稚 screw things up:
1. Is it OK to turn off the PTO and plow with the blower? I was doing this in a few spots where I was worried about rocks. I also did this to build up a bit of a snow berm by a drop off. I am concerned about bending something, but the blower seems pretty stout, and I was thinking this was OK as long as I don稚 push into something hard like a big rock or a tree. Do other do this?
2. Is it OK to turn off the PTO and use the blower to drag snow away from a structure? I can稚 imagine that this would be a problem, but figured I should ask.
3. The tach says PTO speed with a line, essentially at full throttle. Is it OK to run for an hour at full throttle? What about blowing at a lower RPM setting? When I am worried about rocks it seems to make sense to back it down a bit. Is this smart, or not?
4. I was blowing in the M speed setting, moving about a foot of snow. When I started pressing harder on the HST pedal for mode speed, the engine seemed to load up a bit, so I backed off and let the RPM痴 stay up. Is this the correct way to do this? I assume that the HST is designed for this, and it is not like slipping the clutch, right?
Holy cow, this thing can send some snow! Of course, I am graduating from a Craftsman riding mower with a blower, so there is a pretty big difference. Thanks again for all the great advice.
Jim
Jim
