Snowblower for RK24 tractor
   / Snowblower for RK24 tractor #1
dank1
RK24
What front mounted snowblower would work for a new RK24 subcompact tractor? Would also need tractor mounts for this snowblower.
   / Snowblower for RK24 tractor #2
If you have the loader for this thing you would have to remove it. I am unsure if erskines rear to front PTO system and lift would fit on this mule.
You may end up being to use a rammy single stage snow thrower with the bucket removed and an ATV/RTV mounting plate with an atv winch bolted to the loader OR the bucket.
   / Snowblower for RK24 tractor #3
Type
"Canadian Snow Blower Manufacturers" into your search engine.
Peruse the many options until you find a maker that supplies one to fit your RK
Follow the rabbit hole to the one you most like.
It may be M-F, It may be Kubota, or Ford .. the options are endless.
I've got an "as new" BX2816" blower
along with the BX2810 BX2811 K-Connect", Surplus to my needs.
I can't say it will fit your RK, but a man with a welder can do wonders!
eta
It takes less than 6 minutes to remove the loader on the Kubota 2601, and the blower mount fits with the loader frame still mounted.
What does it take to remove the loader on your RK? Less than 15 minutes?
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A48836)
2013 International...
2025 70in Dual Cylinder Grapple Skid Steer Attachment (A49346)
2025 70in Dual...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
Early 90's Chevy Van Bus, Dual Wheels (A47371)
Early 90's Chevy...
1974 Case 580B 2WD Tractor Loader Backhoe (A49251)
1974 Case 580B 2WD...
2018 Ford F-550 4x4 Summit 4416 Crane Mechanics Truck (A48081)
2018 Ford F-550...
