Snowblower Snowblower for Kubota B7510
   / Snowblower for Kubota B7510 #1
Basquill
Woodville, Nova Scotia, Canada
Kubota b7510
Does anyone have experience matching a snowblower to a Kubota b7510? I may buy a used blower or cut a bigger one (72 inches) I have down to an appropriate size. The manual isn't really clear on what is appropriate. It says a maximum "digging depth" of 60 inches and 400 pounds. I assume they mean a maximum cutting width of 60 inches. Also, the manual says a "subframe" is required for a snowblower...anyone know what this is? Thanks
   / Snowblower for Kubota B7510 #2
In 2005, Kubota offered the B2781 51" front-mounted blower for the B7510. It required a B2733 Quick Hitch subframe kit, as well as a mid-mount pto, a pto driveline, a snowblower chute kit, and either a loader valve or a separate hydraulic valve. HTH
My tractor (new to me) is a 2007. The owner's manual must be referring to this front mounted blower (the B2781). I think they made a mistake with the "cutting depth" reference of 60 inches in the manual. thanks for the help.
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2011 FREIGHTLINER CORONADO (A50854)
2011 FREIGHTLINER...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
