snowblower for JD4100
   / snowblower for JD4100 #1
Anonymous Poster
Epic Contributor
I am interested in getting a rear snowblower for my JD4100. I am wondering what size and brand I should get. And what is the price.
Thanks.
   / snowblower for JD4100 #2
Renee,
I'm not familiar with rear-mounted snowblowers for the 4100, but I do have the 47" front-mounted snowblower. If you're interested in that one let me know and I'll give you all the info on it.
Caretaker,
I am interested in the front snowblower also, but I use the loader at least once a week and don't know if it will be too much of a pain to keep changing between them. I went to the John Deere Open House in Concord, NH this past weekend and got very little information from them. They seem to be pushing the 51" rear snowblower. I don't know if that is because they have so many left from this past winter or what. So any information you have would be helpful.
Renee
   / snowblower for JD4100 #4
Renee,
The 47" snowblower for the 4100 is the same snowblower that is used on the 400 series lawn & garden tractors. It's two stage, and it works very well. I got to use it quite a bit this winter, and I'm very impressed with it's ability. Having said that, the one complaint I have about it is that I think it's about 6" too narrow for my 4100hydro. My back wheels are in the wide position, and the snowblower just barely covers my tracks. I'll also point out that the way you drive it makes a difference too, that is you can overcome that "limitation" - and I'll also point out that my neighbor thinks I have an outstanding setup, and that maybe I'm being a wee bit picky about this... but, if I could wave my magic wand, I'd make it about 3" wider on each side.
The snowblower mounts on what's called a quick-tatch hitch that's mounted on the front of the tractor. I also have a rotary broom and a small blade that fits the quick-tatch, but if I were only going to use the one implement then maybe a rear blower would be better. The problem with a rear-mount is that you drive backwards to operate it - get's tiresome after a while. I'm not familiar with the rear snowblower, so I can't tell you how good/bad/indifferent it is. Whichever you decide on, I'd highly recomend that you get the remote chute rotation and remote discharge cap control. My chute rotation is hydraulic, and the discharge cap is cable operated. Getting off the tractor to adjust rotation and discharge angle would get old very fast...and you'd waste a lot of time doing it. I can adjust mine on the fly - makes it real nice and easy to put the snow where you want it.
I have several posts on here - click on my name and then show all posts and you can see the various posts. I recall that I do have a pic in the photos forum under "Never give up snowblowing" - shows me cutting into 4-1/2 foot drift with the snowblower. Like a said, it's a tough beast...
I see that you are near Concord, NH. I live in western NH, near Claremont. If you'd like to stop by, I'd be more than glad to show my rig, answer any questions, etc. I'm pretty flexible time wise - just let me know if you are interested.
I hope this helps some. If I can answer any other questions, please ask.
Dave Wells
   / snowblower for JD4100 #5
I also have the front 47" snowblower on my 4100 and am very impressed with it. I do agree with Caretaker that an additional 6" in width would be nice; it definitely has enough power for it.
I clear a 400'+ driveway with it in 20 minutes or less (in below zero wind-chill, time is important), I think that this would be more difficult if it was a rear mounted unit and would get old real quick. I also need to use my FEL a few times in the winter, changing between the attachments is a fairly quick process, however I wouldn't want to do it every day. Once a week would be tolerable if you have nice hard level surfaces to drop your attachments on.
I also highly recommend the hydraulic chute control, but if you are keeping the FEL on with a rear mounted blower you will have to "unplug" your bucket hoses to get the chute to work making it impossible to fully use both a blower w/hydro chute and the FEL together.
Another nice feature is that once you have the front QuickTatch other JD front implements are much more reasonably priced.
Informational Lot - Financing (A52128)
Informational Lot...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
71053 (A49346)
71053 (A49346)
